Halco Max
jaenswart
I have used them with success at times! What do you think of them?
What colors are your favorites and what speed do you pull them at?
With which other lures do you combine them in your spread?
I love them... Caught a nice little Kingie when spinning from the shore with the Red and Black one a while back...
These are my faves...
jaenswart
I'm trolling these closer to 12-13 knot, with Dorado feather put into the mix. although they do not get as many strikes as the feathers, I do believe they are pulling the fish up into the strikezone. Hard to say.
Richard M
Tried them for the first time last year. Did not get too many strikes, only two on the MAx. Both were on the yellow fin pattern. One take was very savage and we could not stop whatever was on the other end. Eventually cut the 1.2mm leader off. The purple/silver does look good for Hoo' though. Will persevere with at least two in the spread below the konas. I pull them between 6 and 10 knts with no problems.
werries
To me the Purple Max proved it's worth. Got plenty YF at Vidal on them over Deep Oscar's when the other Rappies didnt even get a sniff. In both overcast and clear conditions.
Slowish troll off about 5-6 knts.
The others , like the white/red head wasnt succesfull. Its almost like the purple ondas...if I see one I buy it!
jaenswart
I think we are def going through a purple patch :) but as we all know that changes all the time. I remember weeks at vidal where nothing but pink would work . Next time you arrive you have a tbox full pink but only beads work etc.
I like the max because it is a no fuss lure. And like the old rappie magnums when you get a strike and tap down to start fighting , the other would sink and more than once that would result in another rod bending.
