Guys,
I was out drop shotting yesterday and i saw a guy(also drop shotting) using a bimini twist to join his line to the leader, furthermore the leader was very long, maybe a couple lengths of the rod...........on every cast he had 2 problems ie, the line got caught up on the knot in the reel and if the line did manage to slip past the knot, his cast was very very near as the bimini kept on getting caught up on the guides.
he obviously did not enjoy the little time he spent trying to catch a fish.
i am no expert in drop shotting but if any of you are in fact using a bimini twist knot to join leader to the main line or if you are using a long leader then please take my advise and use the following and you will see that your experience in this type of fishing will be a more enjoyable one:
Joining leader to the main line:
use a double figure of 8 knot, but on the main line knot, make a few extra loops and if you find that the knot is slipping or breaking, try doubling the main line before tying the knot.
Leader length:
I know that a lot of people say that the purpose of a leader is to handle the initial pressure of the sinker upon casting so that you do not get broken off - this is correct, but only if you are fishing with heavy surf tackle, ie, 8oz, etc. however, in drop shotting the jig heads that you use are light and the only purpose of a leader is for abraision resistance against the rocks so i sugest the maximum the leader should be is around 30-40 cm or so that the knot rests just outside the tip ring of the rod when in casting position.
Heavy tackle fishing and drop shotting are two totally different aspects of fishing so we cannot totally combine the two so we have to make some changes when it comes to rigging up our tackle for everyone to start enjoying drop shotting as much as some of us do.
lekker
Ash
Leader length:
lekker
Ash
