gulping 2 stroke
nicsavage
Hi Guys.All your help and inputs would really be greatly appreciated. I have a 5.1m cat hull boat with 2 x 60 hp bigfoot mariners on it. They are 1998 models. The problem I have is that the one uses allot more 2 stroke oil than the other one. Even when just idling and up to temperature you can see it is smoking when in the meantime the other does not smoke at all. Is there a setting somewhere I can try tune? I am not bad with the tools if I have a clear idea of what I am looking at. The motor seems to run fine it is just using way too much oil. Also out at sea that 2 stroke oil smoke is not to good for the stomach. I will really appreciate all help offered. Serial number is 09988964. Thanks !!!
Jaredd
Hi Nic
Google is your friend.
I know that on a yamaha there is a control arm on the oil pump that is connected with a clip that sometimes breaks which as a safety forces the oil pump to pump excessive oil into the carbs . Perhaps your mariners have a similar feature. The motor will still operate but your plugs will be fouled sooner at lower speed if not getting hot enough
Jared
nicsavage
Hi Jarred.
Thanks for your reply. The Mariners are the same. They have a linkage between the bottom carb and the oil pump. This link is fine. Checked it already. My worry is just that maybe one day I drop the boat on the beach and then once pushed into the shore dump it wont start because the cylinder is flooded with 2 stroke oil. There is no other setting maybe on the oil pump itself that is to wide open?
willem wikkel spies
the best advise I would give is:
make up some fuel of 50:1, so that your motor is safe running while testing it.
then you can un plug the two stroke feeding line to the engine.
also just plug the hole left behind.
now with the engine running, see if you can adjust the feeding of 2so.
you can compare both motors speed off feeding 2so.
how much 2so should be fed is unknown, but the good motor should give you a indication.
hoop jy kom reg.
willem wikkel spies
onthou ook, da die kondisie van die motor kan ook n vrskil maak in die hoeveelheid rook.
idle screws, wat nie rg verstel is nie, sal ook n verskil aan rook maak
kyk dalk eers wat die settings van die carbs is.
IWyk
Dis konekteer  die autolubes en pre-mix dan weet jy die olie is reg, veral op die ouer enjins. Dit is n bietjie werk maar as jy n motor verloor in die surf en flip asgv enjin wat vrek gaan dit jou baie kos.
Ek sou liewer nie self stel aan die olie toevoer nie, as jy dit verkeerd doen gaan die enjin seize as hy nie genoeg olie kry nie.
As jy die auto lubes wil hou vat dit liefs na n handelaar toe wat dit kan herstel, maar dit gaan jou waar skeinlik kos
lurock
we use premixed petrol and two stroke. It is important that the mix is done perfectly, but when you get use to the extra effort of premix you'll be happy you did. Our two stroke was also being fed too fast so we disconnected it and went premix. Never looked back again
IWyk
Yip, Pre-mix best and safest route to follow. My two(50 Hp) Evinrudes(19950, have been bypassed and I have total peace of mind.
Last major service indicated 120 Psi compression on all the cylinders, and I am am never concerned that tha auto lubes are over or under oiling.
One tip is to have one person doing the adding of the oil and always do this before filling up the tanks. Dont fill up and decide you will add the oil later, could be disasterous.
nicsavage
Thanks for advice guys. Just a question. You guys mix 50:1 so say 500ml 2 stroke on 25 litre petrol. Do guys add the oil into the can and then fill petrol and shake to mix or how do you mix it?
willem wikkel spies
yip, netso
olie in, dan petrol, dan skommel jy hom soos toe jy jonger was.
al verskil, om hom te skommel het jy twee hande nodig met baie krag!!!!
