Hi Guys.All your help and inputs would really be greatly appreciated. I have a 5.1m cat hull boat with 2 x 60 hp bigfoot mariners on it. They are 1998 models. The problem I have is that the one uses allot more 2 stroke oil than the other one. Even when just idling and up to temperature you can see it is smoking when in the meantime the other does not smoke at all. Is there a setting somewhere I can try tune? I am not bad with the tools if I have a clear idea of what I am looking at. The motor seems to run fine it is just using way too much oil. Also out at sea that 2 stroke oil smoke is not to good for the stomach. I will really appreciate all help offered. Serial number is 09988964. Thanks !!!
:merm
