Guides
Mike Pike
Howzit Guys , thinking of changing guides on my loomis /franklin 13 ft scratching rodrod and purglass 400/2  both 2 pc rods any suggestions on size to go to and how many to change and who does agood job in joburg without busting the bank !!! ta okes any info is welcome .:thankie
Mike, I've had a couple of repairs done by Anglers Den in Edenvale. Their work is solid.
ANGLERS DEN - North Reef Rd, Bedfordview
Phone 011 450-3548 speak to Anver Latib
Oh and size 16 guides would make your job of casting big knots MUCH easier...!
Anglers Den still have some of the original Fuji's - the ones that have a stamp on the side of the ring - they're great in my opinion... but Pac Bay are apparently better??? Dunno, never used them.
Weedeater
Hi guys,
Pac Bay are definately the way forward, the Titanium oxide guides are practically indestructable and last forever.
miles
Hiya
Pac-bay or Pacific Bay, is an inferior guide to Fuji guides. Check out your local tackle shop's deep sea big game rods. The cheap rods are equipped with Pac-bay guides/roller tip, whilst the better rods use Fuji and the BEST use AFTCO roller guides.
There was a lawsuit some time back where Pac-bay sued Fuji, for some trademark issues. Can't recall the particulars, but Pac bay and Fuji are competitors in the fishing rod guide market.
Pylstert
Pac Bay are good and you can pull a file through the top spec ones and it doesn't make a mark, but if you speak to those who repair rods, the rings have a tendancy to pop out very easily. On the cheaper Pac Bay it happens very easily, almost as easily as those eyes on Shimano Exage rods. There is apparently a new Fujy out that the Assassins are fitted with, apparently excellent, but not freely available
Weedeater
I have Pac Bay Titianium oxide guides on all my rods and have yet to have an issue with any of them. These particular guides are certainly not cheap, range from R45-R75 a guide depending where you get them from.
The new Fuji guides on the Assassin range are great, the Surf Series HMG's come std with them, I haven't seen them before the Assassin's, so I have no idea where to get them.
Pylstert
I think the new Fujis are only available on the new assassans at this stage. I had my cheaper range Pac Bays on my Beach Master pop out. On my one old exage, 3 rings went, who knows what make those eyes were.
I have luckily had no problems with my Pac Bay titanium oxide, they are fantastic but was told by the rodbuilder that put them on one of my rods that I must be careful bumping them. Those that fish the reefs and other rough places down here prefer to have the old Fuji eyes fitted.
Weedeater
[color=#006600]miles[/color] wrote:
Hiya
Miles,
You're not comparing apples to apples here. Surf rods have different requirement to deep sea big game rods, deep sea big game rods don't require the user to cast whereas surf rods do. That's where the issue comes in with surf rods, the reason why most 'heavier' surf rods require decent, big guides is due to the large leader knot going through the tip eye at speed.
Most reputable rod builders use the Pac Bay Titanium Oxide guides over Fuji's, case in point, Gremlins and WAFT. I spoke to Rob and Brendan about this and they both were alot more inclined to go with Pac Bay Ti Oxide guides over the Fuji's.
Weedeater
Yeah, I've only seen them on the Assassin's so far.
I haven't heard anything negative yet about the Ti Oxide guides, in fact quite the opposite.
Pylstert
Weed, there used to be a Fuji eye on the market that was better than Pac Bay, forgot the model number, but for some reason they stopped making it. The rings were seated very firmly. It was certainly the preferred eyes for surf rods. Now we will have to see what the new Fuji is like and if it is going to be available to us or just for Assassin?
Jude
Hey Mike try Mia's in Woodmead or Randburg, Fuji 16 same as the Exage 1468, big knots slide through them.
Blanky
I'v seen the new Assassins eyes, the eye closest to the reel seat can fold if im not mistaken??
I need to get bigger eyes fitted to my WAFT Mako Shark before summer but i have no idea which eyes to fit.
Also, do i replace all my eyes or just the front few??
Have any of you guys had eyes replaced on a WAFT??
Mike Pike
Thanks Jude , going there on sat morning will see what they offer and price comparsion to others i"ve spoken to . :shark
Weedeater
Blanky,
The 'new' Fuji metal guides are not readily available, so rather go for the Pac Bay Titanium Oxide guides, they are very good and you shouldn't ever have to replace your eyes again after that.
If you're getting new eyes put on, see if you can get the winch replaced with a Pac Bay 24mm trigger, makes life alot easier.
skrops
Took my rod into Anglers Den on Saturday, asked him about solid steel eyes and suggested Muldrum eyes..........any opinions or knowledge about them?
Polychaete
Just a comment, changing the guides on a rod can change the "feel" of it.
I once replaced all my guides with the biggest I could find to see how it effects casting and realised that I could feel the additional weight, possibly wind resistance, and it also effects the flex of the rod.
Probably not important to most people, but I quickly went back to "normal" size.
