Grooter baber
baber31
Hello almal. Wil net hoor of julle dalk tricks het vi my om te probeer. Baie kere kan ek nie n platanna kry of kuiken nie, so dan gebruik ek chicken liver en hearts maar dit voel vir my die kliener baber tel dit op elke keer wat kan ek anderste doen om seker te maak ek kry grooter visse op die lyn? Groete
hunter59
Hi Bud. Pity u Can't get Platties next time u in KZN let me know so i can trap u some (0662435363). If u really need platties ask farmers if you can check their pumphouse Filters and Non-Return Valves i used to catch most of mine in the Pump houses. Old Cattle dips and small dams with no fish are also great places.
In the Meantime see if you can get your hands on some hand size and bigger kurpers and use as live bait or freeze them in Ziplock Bags Gills cut off and soaked in Supercast Barber Dip. small bass from overstocked dams are also great. Cut their heads off and their bodies cut them into cut baits. I usually tie them like a sardine on a surf rig. The bass heads, cut gills off and soak in Supercast or Conoflex Barber dip. And cutlets also in a bag with Barber dip. Just remember with heads crush them with a flat mallet or with your shoe to help squeeze extra flavour out. I usually Do this at the dam.
Buy or Make Some Plain Boilies, Soak them in Barber dip or in Blood you can get from the butcher. When i get to the Dam i throw Out These Boilies on a Hair Rig. And then i shoot the others out all over my feeding area with a Kettie. When i get 2 quick Barbel takes (small or Big) i know the Cats are on and i start throwing 1 Rod with a Whole Kurper (If i have) or Carp or Bass head thats been soaking. and the other rod i throw with a Cutlet (with the Derms) thats been soaking in Barber dip. Cats then come cruising. Tight Lines ::tight:
deisel
The answer is simple. Big catfish eat fish when they grow to adult sizes. Platties livers and birds all catch 1 to 8 kgs models. Buy tilapia from the butchery if u cant catch fish to use. Not only are platties illegal but its very cruel to drown a frog like that its a bit unnecessary just to catch a small fish
willem wikkel spies
lo, ek het vir daai 1 gewag.
yip, bigger fish needs bigger bait.
but you can also catch a big fish on smaller bait.
the trick is to put the bait out at the right spot.
small fish will always run off with big baits as they will try their luck.
perseverance is what you need.
it will happen, eventually
stywe lyne
deisel
I said nothing of bait size only if bait type I use small live muddies or fish heads. Big catfish eat fish regardless of size.
willem wikkel spies
guys, please just note.
live bait in fresh water is not legal.
all bait presented must be dead.
what you do, what bait you use and how you present your bait is not my concern.
im just bound to inform you of the above.
so, who is fishing where this weekend and what will your bait be?
fishy_fishy
Excellent post! Will try this technique. Do you cut off the dorsal fin of the Kurper?
((goodp_
