grinder for 10' rod
Joker
I'm in the process of getting a 10' spinning/grinder/scratching rod.
Which reel would you guys recommend. Also the size to balance the 10'.
Do remember I'll be using it as a saltwater set-up.
Thanks in advance.
Joker
POSTHUD wrote:
I have the Daiwa Exceller Plus 4000 on my 10 ft rod, at under R1000, it is a great reel for the rod..
Thanx POSTHUD
May I ask what the line capacity is for the 4000 plus? Also are you spooling with mono or braid? Dia(lbs) for both.
POSTHUD
Hi Joker,
I have 300m's Berkley Fireline 14lb on one spool and 300m's Sufix Braid 20lb on the other spool.
Joker
Thanx POSTHUD
I take it the Exceller plus has two spools.
Having the different lbs braid helps with taming those bigger fish :)
Strepie
I use a Penn Sargus 4000 with 20lb Sufix 832 braid. Reel only has one spool though but that is enough for me at this stage.
Joker
Hey Strepie
I felt that reel. How does it match your set-up? Dont you find the Sargus slightly heavy... Just asking and I know thats a solidly built reel.
Mengs
I also have the Sargus 4000 with suffix braid which I use on a 9ft megaforce. I am very happy, tough little reel, an upgrade would be the Penn Battle, lovely reel, but a few hundred rand more.
Strepie
Joker wrote:
Hey Strepie
Does not bother me but it might bother someone else. It is definitely a very solid reel.
I have it paired to an 8ft Vengance at the moment but will be looking for a 9ft or 10ft as well to use with it in the near future.
Joker
Thanx Strepie
The reel is 4000. Consensus reached. :)
Now the question of braid. I might have one spool only.
1. Should I go for name brand? Quality.
Any recommendations. Your experience.
2. The round type? For better line lay.
3. What lbs? For all round spinning/scratching.
I'm thinking 14lbs or 15lbs depends what's available.
Thanks in advance.
On Dad
The better braid to use is Viros 20 or 30lbs - other braids seem to get a bit ``fluffy`` after a while! Use 20lbs for the surf or rather 30lbs if you fish off the rocks as well - the loss of casting distance for the 30lbs is very little - my 13 year old son pulled a 17 kg diamond out in 10 mins on a 9 ft with 30lbs braid !! I have tried all sorts of braid - Viros stays the best - 300m @ about R300.
Joker
Thanx On Dad
So its a toss between the 20lbs and 30lbs... Pity I dont have two spools.
I have not seen the Viros in stores in cape Town yet... but will give it a closer look.
PatrickC
Shimano Sahara 4000 is also a lekka reel! Using it on a 10' vengance at the moment and its great. Its very smooth and has a great drag too!
On Dad
smiley6996 wrote:
i am useing a daiwa regal 4000 comes with 2 spools and its a good price i love that reel works like a dream for me
Brother , I bought one of these and they come at a good price for such a budget reel. Pity that they are not really made for saltwater ( daiwa leaves this part out ! ) I recently purchased a Shimano Sedona 4000 from Gani`s angling world in Witbank for R515 ( r450 & r65 postage ) - super reel !! & much better quality too .- other shops sell them for about R 850- R900 - the Shimano exage 4000 is just as good & also has 2 spools
