Grapnel Sinkers
dup-zn
Now you slide your spring steel into the holes at the bottom of the sinker. The wire must be in the middle.
dup-zn
This pic is the way I store my sinker in my tackle box. no wires sticking you in the back and damaging your equipment. I would then bend the wires when I'm next to the sea.
dup-zn
When I get to the beach I would drop the wires to the bottom and bend them in the following fashion.
After a while you will know excactly where to bend it. I've had some practice over the past 5 years.
dup-zn
You do the same to both spring steel wires and you should end up with something like this.
dup-zn
I have spring steel wire available.
It is 1.6mm and will work perfect with the 4,5,6and 7 ounce mould.It is cuy to the right length. They are in bundles of 200.
For the 8,9and 10 ounce mould I will have 2.0mm Spring steel available.
dup-zn
Hi Ian.
I use 1.6mm mig welding rods. you will be able to find it from any welding shop. I know Affrox sells it in kg bundles.
dup-zn
Hi Ppl
Just bought 200kg of lead wheel weights at a bargain of R7.00 per kg.
I am busy melting those wheel weights to get the clean lead and remove all that bits me steel that comes with the wheel weights.
I simply just fill my melting pot with the wheel weights and let it melt the steel bits floats on top of the lead. Once the lead is clean i pour it into 1kg bars using a 50mm angle iron with divisions.
dup-zn
Hi Ppl
I finaly got some time to make some sinkers for myself tonight.
Made the following
7oz   X     30 sinkers  = R300 at tackle shop
8oz   X     15 sinkers  = R180 at ackle shop
9oz   X      20 sinkers  = R280 at tackle shop
Total cost at tackle shop  R760
It cost me R100 for the lead and lets say R50 for the gas and wires
Total cost for me was R150
I just saved R610 by making my own sinkers.
will post some pics tommorow.
Dup.
Harry
Hi Dup,
Where about are you ?
How do i get the moulds from you if i wanted to purchase ?
Do you have the shorter fatter grap ?
I tried your email address......no joy there.
Please let me know ASAP....thanks bro;)
dup-zn
HI Pll
Had to make some sinkers for myself and a friend that will be fishing Hartenbos.
Got a little caried away.
Made 195 sinkers in one afternoon.
Here we have 50 X 7oz grap sinkers.
cost at tackle shop = R475
dup-zn
Here we have 70 X 6oz sinkers
20 of which is nylon grapnell
tackle shop cost = R560.00
dup-zn
here is 40 X 4oz grap sinkers
of which 30 is nylon graps
and
15 X 8oz grapnell sinkers with long shafts.
tackle shop cost = R385.00
dup-zn
thr total cost for the sinkers should I have gone and bought it at a tackl;e shop
+/-R1700.00
My total cost was
+/- R500.00
Here is some of the moulds i used to make the sinkers
TREV
Howzit Dup
Very interesting...
when making the sinkers with th nylon grapnel, how do you keep the nylon from coming out of the holes, & what nylon can be used??
DWB
Use the 2.7mm or 3.0mm red weedeater nylon.
Drill the hole bigger and then insert the nylon and use a hammer with a punch and then just indent the lead, it will keep it VAS
