In the beginning of this year, I had the privilege of having a few casts with a proper Japanese spinning rod. Long story short- I fell in love. I had to get one! Nothing on the SA market would be good enough anymore.
After many false starts and backwarding and forwarding, I got hold of a GraphiteLeader Tiro 8'9FF through Rolfe from Lureshop.co.za about a month ago. Unfortunately, I had to on 2 weeks holiday to England/Portugal in the month (tough I know) So managed 2 sessions with the rod down at my local.
Firstly the rod has a Regular-Fast action with lure weighting of 7-32g. It is meant for lighter applications, and being Japanese those ratings are accurate.
Where to start? OK so I got down to the spot and I had already decided to fish the lower section close to the mouth due to the falling tide and flood water. Kitted up and saw elf breaking the surface. Bit of a mission sorting out my winter clothing gear- wetsuit longjohns, neoprene socks, water shoes, 4 layers on top. The conditions were tough- winds of 10m/sec, some rain and air temp of 8C. With windchill it was a lot colder! But on to the rod! I cast various lures from Megabass Fluttabait (35g) to Zonk 77 (12g). It handled all the weight ranges with ease with the sweet spot about 20g. It seemed to punish lures that tumble more than my other rods, if that makes sense. I found that I casted further as the day went on. I am not going to speculate on distances as the wind was in charge but there was a definite increase in distance. I really like the RF action as you seem to load the rod better. On retrieve I had amazing sensitivity. I was concentrating deeper down, trying to get the lure just off the bottom. I could feel every movement of the lure and grass, rock, sand, mud were all distinct feelings. The one bite I got early on was a solid thunk. When I was driving home and thinking of the day I realized I was manipulating the lure so much better, especially keeping it just of the bottom. I had total confidence that I could take the lure into the bottom and not get hung up as the slighest bump was transmitted very fast and I could react before it hung up. Yeah, the rod and I bonded really well! I played with a ZClaw and was blown away at how well I could make it walk the dog. At a fast retrieve, each tack ended with the lure at 90 degrees to the line. I even was buzzed by 2 leeries. As the tide dropped further I went to a rocky point that has a deep hole in front of it. Using a Sinking Shad I was casting upstream and just keeping tension, with the occasional twitch, drifting the lure through the hole and up the rockbar on the downstream side. A solid take with a fast hookset and I was on! I put some stick on the fish and in a minute I had a 70cm cob. The rod and Stella reel worked really well. Totally smooth with excellent constant tension. There was loads of power in reserve that I did not tap into. This rod can handle a lot more. I can't speculate to what size fish but a 15kg cob should be no problem in the right conditions.
