Grandwave verses Saltist
I was wondering if there is a major difference between the two reels ...as in internal workings eg; drag , bearings and gears    ...  i know they look diiferent and they have different prices
Ziyz
Grandwave has a disengaging spool. This gets you more casting distance, but supposedly reduces the maximum cranking power you can get out of it. I'm not certain, but I think the retrieve rate and line capacity may be slightly higher on the saltist.
Walt
Which size reel are you referring to?I have G/Wave 30,Saltist 30h and Saltist 50H.I can't comment on G/Wave 50 as I don't have one.
So with regards to what i do have,and best I can offer you,is it's like my Honda vehicles.I have one that's new and one that's under 10 years old i use as fishing vehicle.Latest one has latest technology and is far superior in all ways.
Confused?What i'm referring to,is that the Saltist being a later model,is a major improvement on Grandwave.Saltist has better drag,better cranking,better finish and is far more durable.But probably far more expensive than Grandwave.Saltist,far more durable,stronger drag will catch the bigger fish than a grandwave would.Both hold same quantity line,and for smaller fish,Grandwave will suffice.My cast is very similar on both reels,both having had brakes removed.
Just my 2c!
old salt
HI they both are good reels the GW i personally prefer for edibles the reel is more resistant to salt corrosion, the split shaft casts easier. there is no one way roller bearing on this reel, the handle is offset with a counter balance. It has bearings on the load points.The frame is graphite so unaffected by salt water and its light.
The SL50SH i believe is more durable than this model and handles shark better also. The 5 points load support system works exceptionally well the drag is good and the bearings and drag stack is big too, there is nothing fancy to break and fall off the handle has 2 settings for normal load and to crank also.The bearings are nice and big the design is simple robust and most durable,the spool is very light yet extremely strong, this is prberbly one of there most succesful daiwa reels todate and still very popular.I prefer this model out of these 3.
 The saltist is good too, alloy frame so not salt resistant, the gears are strong, there are bearings on the load points. it has a powerhandle, the drag stack is large 5 washers.  It has an anti-reversion bearing to back up the dog. The reel has a large line capacity for shark.its also very good except i hate the frame the material is not as durable as the sl or GW range.BUt stil a good reel, the big draw back for me is the heavy weight.
Mussels... some conflicting and erroneous advice been given to you here...????
In my opinion... (I own both reels and fish with both)...
You can't compare the Grandwave to a Saltist... different class of reel. The Grandwave was built for superior casting since the spool disengages completely when casting. It is primarily an edibles reel, although there are some who use it as an allrounder, it is not going to stand up to the punishment of being a dedicated reel for sliding and Shark fishing.
The build quality cannot be compared - the Saltist being vastly superior, having an ALUMINIUM frame and therefore being highly corrosion resistant! The Grandwave being Graphite, and therefore not as strong. The handle of the Grandwave is very poor, having broken twice on mine until I upgraded to a Power Handle. You also cannot compare the retrieve of the 2 reels - anyone who does, has not fished with them!
But please, don't let my words confuse you... Next Saturday... GP social, please come and have a look for yourself... you can try them both out for yourself... and then you will see what I'm talking about...
Ziyz
:raine
From Daiwa's Website:
SALTIST:
Built For Today’s Super Braids
Introducing Daiwa’s new Saltistâ„¢, with the features and rugged “Full-Metal Jacket” construction demanded by today’s ultra-strong braided lines and mono. Choose from standard 4.9 to 1 retrieve or new ultra high speed 6.4 to 1 retrieve models that rip in over 47 inches of line with every crank, just the ticket for Kingfish. Saltistâ„¢ Features:
  • Rugged, all-metal construction with rigid, one-piece aluminum frame [/*]
  • CRBB shielded, Corrosion Resistant Ball Bearings on spool [/*]
  • Super Drag [/*]
  • Total of four ball bearings and roller bearing [/*]
  • Up to 30% greater winding power [/*]
  • Aluminum rod clamp [/*]
  • Powerful, high-strength alloy gears [/*]
  • Dual Anti-Reverse systems [/*]
  • Dual-position power handle [/*]
SALTIST STT50H
Thanks Reef i will see you there
Ziyz
Now, to rephrase what I said earlier in a more accurate manner,
For the high gear models in the size 40 and 50, the amount of line retrieved per handle turn ;) is greater on the saltist. From personal experience, I've also found cranking the handle to be more efficient on the Saltist. I don't really know how to explain this. Perhaps its the higher gear ratio that gives it more torque. You best bet would be to take reefman up on his offer and see for yourself.
:addn
Def-e-nition
 Oi , reefie Man .
You see the GW has had a bit of an upgrade in the handle department ??
 I went to the Daiwa Site and found two versions of the X Range .
The One I saw On sunday in our local store now has the handle fitted to the lower geared , and I would imagine , American , Model ( although a lower gearing for bigger fish coupled to long casting - makes No sense to me ) and is Now MUCH MUCH stronger - a Copper version of the Saltist handle . Me like this Reel Plenty .......
I'm after a Gw 40 Now myself .! Would you  take the Sl 30 Over a Gw ??  I would imagine that thing should be able to cast a Mile ......  but In general , after having both 50 and 30 Sl in my collection , The upgraded handle on the Gw impresses . I ordered one for the Sl30 , as it seems to be corroding on the handle bush itself .Squeaks annoyingly until you grease it/wet it, when retrieving ...
But In general , I am impressed with the overall feel and finish - Not to Mention that spool de-coupling ,and spinning forever  in the  store ...grin ......
old salt
Hi D
now that i am awake  and not studying let me respond i have had all those reels and fished them as well for a while, the lower retrieve would proberbly be the 4;9;1 version this reel was stronger on the gear front and the gears chunkier but kingfisher stopped bringing this one in as the surf guys wanted the faster one mainly.all the new models come with that gold power handle its the same as the saltist just gold in colour th e20-30-40 and 0 all come with this same handle hope that helps.The slatist does nto have an alluminuim frame but pueter if spelt correclty  that why they and the torium have corrocion problems form the inside out, the saltiag and trinidad however do have aircraft grade alluminium frames if memory serves me right. The graphite frames on the old reels are much stronger than most people realise it can take a lot of abuse as weil never rust or corrode no matterif it sleeps in salt water, About 2 years back i had a very interesting discussion with th epwner of kings Mike P and well he shares some sentiment with me that many may differ on. I do believe the SL50SH is first then the GW 50 for edibles the saltist gear train is stronger but i have a tendancy to dislike heavy reels especially for edible fishing when sometimes stands long with a rod but once again its all personal preference each to his own, thats all that matters, tx
squidgy
Hi guys,
The saltist is a stronger reel due to its full metal construction, however, this is not to say it is the most corrosion resistant. Graphite is much more corrosion resistant than the saltist's "aluminium alloy". It is aluminium as Reefman states, but it is more acurately aluminium alloy, a combination of aluminium and other metals, making it more corrosion resistant than carbon steel or similar but not as resistant as pure aluminium or the aircraft grade stuff that the saltiga is made from, and definitely not as resistant as graphite, but it is much stronger than graphite and will not break as easily if dropped on the rocks.
I do believe that the saltist is better for ineds, but not because of its gearing or line retrieve, although it is marginally more powerful on retrieve than the grandwave, but merely because most of the components are metal and will therefore take more pressure before showing signs of stress. The drag is also better on the saltist, and the great part is that the saltist's frame is strong enough not to distort under heavy drag pressure.
They are both good reels though, and both are available in high speed and standard speed options, and ultimately it comes down to personal preference and budget.
old salt
Hi Squidgy thankx for your input as well it sgive the gentleman a broader spectrum of opninions to decide what he thinks tx
Anchorman
The Grandwave is a very good reel for edible fishing and I'm almost certain it would easily outcast any other reel including the saltist, although the saltist is a much stronger reel and is built from materials that could take much more punishment, but my humble opinion is ,that if your not going to target non eds , then your not going to need a stronger reel than the grandwave or SL50 or if your only going to target non eds a few times, a grandwave should survive
old salt
Hi R
the torium 50 is a great reel but obnly for shark from ledges where a big cast is not needed one would proberbly target the realy big shark with a big libve bait sharks of 180kg upwards it has the stuff for that so it is therefore a specialised item that has only that purpose i have seen them perform in the cape and i can only say good things about it. The torium 50 and the big Newells target the big species mainly the Newell are becoming a rarerety these days i am not certain if errol holmes still bring them in they are no nonsense reels that get the job done and they are of the exceptionally big reels that can also cast a LONG LONG way indeed.
