GRANDWAVE 50 OR TORIUM 30
batista
hi all
I am looking at investing in a new reel and cant decide between the grandnwave 50 or the torium 30. I am looking at purchasing the reel that casts better and further. Any info wrt the above will be greatly appreciated.
Volcom
Hi Batista,
I have both reels and while this lil bit of info may come from personal experiance, id have to say when casting and distance are factors....id go with the Grandwave.
Im using my grandwave with my BeachMaster, heavy tip,  and coupled with a 6" sinker im almost taking out a ski boat.... ::craz
Torium puts distance too but im sorry Shimano, Diawa takes it this time with the long distance Grandwave.
I agree..the grandwave does cast more easily but only because off the speedshaft!.. Thats where the pro's on the grandwave stops! As an altogether better package the torium rocks it though...its more well built and more capable to handle anything...
BRENDON
Shimano is by far a more superior reel. the Torium can handle anything from your small fish right up to the busses
ICTHYES
:eek:tp::
and "she is pregnant" ..."I shall not surcome to sponsorrrrs"
most people go for shimano....thats gona be my next reel  under guidance of Brendon:first
Razeen
I agree with Brendon on the cranking power, Stumpnose tend to swim on top of the water when reeling them in with the Torium i lost 2 fish like that. Diawa's are much smoother and cast further. They are great for edibles.
I was told by a WP oke that for Eds the Diawa's are finegr8.
I had both the Torium and the Grandwave 50. The Shimano's are heavy reels and thus your rod must be balanced to this. your cannot have a feather for a rod and a brick for a reel. That's why i changed my outfit to Diawa 30's a Grandwave z 30 and a grandwave 30. With a Blue Marlin T536 and a Shimano Exage 1446. So I'm not pro Diawa or anti Shimano. Just don't make the mistake i did unless you enoy buying swapping tackle, I bought the Diawa so i can get more distance and the 30 gives you that edge on distance as oppose to the 50 but lacks in Line capacity if you have an overwind and need to cut the line off. So either a spare reel or a spare roll of Line in the tackle box.
My reel cycle Shimano Speedmaster4->Torium 30->Grandwave x 50->2XPenn 500->Grandwave z30+Grandwave X 30.Last 2 Grandwaves are for keeps.
Khani
Hey Batista,
we haven't fished since together since the arrival of your little bundle of joy, lets fish soon and you can try out my Grandwave and then compare it to Ronalds torium.
For edibles the grandwave is more than sufficient and you have the Saltist that u use for non-eds.
But for pure all round performance and power the Torium outguns the Grandwave.
