Gourikwa Reserve, Gouritz
We have booked at Gourikwa Reserve. The place looks stunning and I would like to wet a line.
Any tips or advise on fishing spots in the area? Its our 1st time there.
Spool-Song
Fantastic fishing spots if you like fishing from the rocks. A good spot for cracker. Bring strong leader material (+/- 1.0mm) and lots of sinkers. Fish the working water on an incoming tide. Alikreukel and crab on a big strong hook.
Lofty
One tip,when you use Pilchard or Chokka as bait always put a little steeltrace on,you dont want to loose a bus Elf because of that.
Two ours before low tide start fishing the reefs and shallower water and as the tide chase you away work to the higher areas where you can stand on a bank for eg or at a place where you can fish the deeper water.
Pink prawn is excellent bait also fresh Rooiaas and spring tide the most productive with a SW wind.
When you fish right in front of the fishermens houses on the rocks check the waves and see that the water dont come over the higher parts of the rocks,that places are excellent when the water is quite and you can catch any fish there,if the water come over the higher rocks stay away and fish another place.
SPARRABOS
Bring altyd herinneringe terug... Vir n Paar mense nog tot vandag verbitter oor hul grond.... Maar nou ja... Wat kan ou teen n regering maak.. Niks..... Daar was destyds 4 plase by buffelshoek... Ou regering hul onteien... "mark waarde" gekry wat niks was.... Kernkor span als toe... Omheining ons belastingbetaler Meer gekos as grond... Soldate verskyn.. No fly zone... Lemdraad tot in see.... Geboue word opgerig... Patrolie bote.. Conspiracy theories... Sou eers later by bejaarde oom hoor wat vir destydse regering gewerk het wat regtig daar gebeur het... Sal maar niks se... Wil nie verdwyn... Bos bokke kon nie rond beweeg.. Was binne omhein.. Moes as kind kyk hoe word hul geslag... Kan nie oor my hart kry om n bok te skiet... Streepsakke alikrukke gemors daar... Ja die elite kon daar maak onder dek mantel wat hul wou... Rietsnyers en hengelaars verban.... Ek en my broer en oom Ben die een kleurling oom steeds daar gaan vis... Oom Ben my geleer stompkop vang daar.... Maar ou was altyd on rustig as jy daar binne was... Toe na jare verkoop regering alles oornag aan n duitse rein.... Nuwe regering oor gevat... Plug was gepull op alles.... Rein dit spot cheap gekoop.... Na rein was dit weer verkoop aan huidige eienaars.... Genoeg nou van geskiedenis... Sal bietjie praat oor hengel daar...
SPARRABOS
Ek vat net een grafiet stok van so 13 voet soontoe... Ou blue marlin of purglass... Vis winter en somer met Selle outfit op klippe... Maak nie saak waarvoor ek gooi... Nou spoel multiplier soos 40 saltist... 45 pond Maksima marine Green... Jy pak jou dipstok bamboes handstok in.... Strepie hoeke... Koldas hoeke... Elf kabeljou en stompkop hoeke... Paar 5 onz sinkers.... Aas vat jy net klomp bokse sardyn of pilchards saam.. Of jy gaan haal op mosselbaai pilchards as jy iemand Ken... Die pilchards is om lok plek te maak en om aas te vang.. Jy vat n seekat haak en skerp lig ook saam....niks Meer... Sien ouens gaan met coolers vol fancy aas see toe... Nie nodig.... Jy vang vir jou strepies of Steen tjies en haal een Kat uit... Beste aas vir daar.... Herfs is goed vir blou elf... Kabeljou... En poenskop of blou stompkop... Roman byt ook graag die tyd van jaar... Glo in viking hoek vir elf en kob... 8.0 of 9.0.....en dik nylon strop... Weedeater gut... Dat hul jou nie afbyt daai monster elwe.... Vir stompkop haal skulpaas uit daar Baie... Of krap... Los laaang dik leaders dit breek af en men's verloor net vis in daai stukke gemors wat agter bly... Gooi strait hooflyn... Swak sinker trace...45 pond Maksima land jy enige vis op klippe..... As jy klaar strepies vir aas gevang het Hou vars op ys.. Dan as jy harde wurm het kan jy kolsterte en stinkvis en pense vang met dipstok... Daar Baie... Ons vat altyd yster pan en gasstoof saam elke aand kan jy vis en vetkoek bak... Terwyl jy na see kyk
SPARRABOS
Daar Paar goeie plekke in area..... Waar oom Arthur fox se plaas was is fox se baai.... Jy vis daar as suidoos sterkerig waai... Jy sit aan kant waar jy amper so skuins saam oos wind gooi.. Nie aan Ander kant.... Jy kan ook daar vis as oos gaan le... In suid kaap kan jy nie laat slaap... Jy gooi as dag breek tot 9 uur.... Of laat middag... Ons Baie elwe hier gevang en hier en daar n mooi kabeljou... Jy kan daar vir beenbek cracker ook gooi..... Volgende plekkie is plastiek baai waar goed van bote so uitspoel... Ons Ken hom by n Ander naam... Goed vir spring gety... Jy begin heel voor vis op laag... En skuif terug soos water stoot.... Oom kabous daai moerse 8kg elf daar gevang... Elwe byt nie dik daar maar dis groot groot elwe... Jy moet lok..... Op laag daar voor is goed vir beenbekke... As jy n galjoen hoek aansit en jy sandkrewl en witmossel daar is groot pens en derms..... Marais se bankie is goed vir elf kabeljou en kraker... Pasop net as dit spring gety is... Jy moet betyds waai voor water te vol raak.... Op niptide kan jy nog bly staan en vis op hoog maar nie op spring tide.... Rooibankie soek ook n ooste wind... Jy soek water so uur voor hoog tot op hoog en uur sak... Oom Louis Botha sy elf en kabeljou daar gevang... Meeuvlug... Hier byt groot rooi romanne en blou stompkop... Wees net versigtig vir groot see by Meeuvlug se banke.. ... Jy kan maklik versuip.. Beste op leeg water daar te vis... Romanne byt Meer na links voor jou uit.... Dan skool se bank waar ou plaas skooltjie was... Daar is beste elf hengel plek... Groot elwe en Baie elwe.... Roman's en santers like ook daar byt in koue see... Daar ook mooi kabeljou daar..... Die vywer area kan jy net op spring leeg hengel.... Jy vang mooi kabeljou en elwe daar
SPARRABOS
Oom jannie en my PA hulle by Capri boot uitgevat... Dageraad WA wiele en blou stompkoppe gevang.... As see rof is staan hulle by vuur... Drink en kyk hom kalm want hul Wil see toe.. Maar hy word net rowwer... Lol.... Daar daai sloep met oop see waar hul gese het 60 pond nylon Hou nie vir rooi steenbras nie... Ons daar gegooi... Ek van daai goed geland.. Lol... Maar was toe Ander visse as wat PA en oupa van vertel het... Ek dit vermoed... Maar wat n lekker fight.... Ouens moet maar self daar gooi om te sien wat dit is.... Pragtige wereld daai... Herfs nou is Baie goeie tyd.... Wens ek was daar
