Gooi hom
DWB
There is plenty info regarding this. Do a search and im sure you'll find something valuable.
What baitcaster are you using?
michael grey
It's very old daiwa reel wanto buy a new one but first want to learn how to cast that type of reel(always get a overwind)
DWB
michael grey wrote:
What is the best baitcasting or spinning?
Depends on what you wanna do, generally the baitcaster can be a more effective and accurate tool. Accuracy on a Baitcaster especcially when lure fishing is unbeatable. But a spinning reel can be a very effective tool in the right hands
DWB
Set your spool tension so that when you keep your rod tip up and allow your lure to drop down that it does so nicely and does not cause an overwind once it hits the floor. then start like that
Basspro
Baitcasters are almost intimidating to most anglers and that's why they either battle or will not use them ...
There should be a knob (I'll call it that) on the handle side that either tensions the spool - the lighter U tension it the more nests U'll get if U not careful ...
a friend of mine gave me lessons in baitcasters from casting/flipping/pitching settings and maintanance -- now I can do it all myself ..
ask someone to physically show U the ropes .. it's a fantastic piece of engineering !!
Skuimkop
And remember to keep your thumb lightly on the spool/line while your line is running of your spool after your cast but not to tight. Just enough so that the spool can still run freely. This way you can stop the spool when it starts to overwind and with time you don't need to worry that much about the tension cause you can control it this way.
Tip: Ask someone with the PENN tipe reels to take you for a casting session were you will quickly learn how to cast with those tipe of reels and then it is so much easier to learn how to cast with a baitcaster because you know the basics and works of those reels.
Hope it makes sense cause its moeilik to verduidelik in English. lol
Vleipadda
Skuimkop I had that problem with my penn lol I got a magnetic jobby okuma no overwinds yet  Dont know wether You get a baitcaster with magnetic assistance though
Vleipadda
Micheal I paid R510 on a special it wasnt the top of the range though my passion is freshwater not rock & surf
the name is Okuma Contoura Skuimkop ekt amper nou n hartaanval gehad
Skuimkop
Heavy nê. hahaha
Ja ons boys en ons toys maar jy sal veseker goedkoper kry maar die heel goedkooste sal maar wees om op die harde manier te leer om met die gewone baitcasters te cast en vir jou dan so een aan te skaf. lol
