Good casting / multiplier rods for straight braid
Marthin
RobG wrote:
Look out for a Purglass Executive second hand.
I managed to accumulate the 400/4, 400/3 and 350/2 all best rods I have ever owned for their own purposes. Took me about a year to find. They are out there and people are selling cheap to but into the multiplier frenzy
Hi Rob.  Yes i have the 400/4, the 400/2 blank that i still need to have done up, and a 350/2 for my son.  Rod works well with both grinder and 15/30, casts anything up to 4 ounce a mile, light to handle the whole day, and ive taken it for myself more times than he has used it.
DJP
Thanks for all the inputs guys. Things have been a bit manic this side, Eishkom isn't doing anybody any favours.
I use to own one piece Purglass 400/3 and 400/2 (and still have a 300/5) all bullet proof but there was a time when three piece rods were just easier for me to transport. I'll be stoked if I can get another 400/2, use to cast up to 6oz with it. Those blanks are tough and quite thick so a bit heavier than the blanks we see come in the market today. Second hand market is odd at the moment, especially with the casting rods, seems a lot of the people want to ask what they paid for, for old used tackle... don't quite understand it.
I'm going to check out the Okuma Precision rods, I just need to get around to a shop that sells them, for me the balance is really important and that differs from person to person.
Just on why I'm looking for a casting rod instead of another grinder setup (I have a few, all work well for their intended application). It's really about the thicker braid, and not breaking strain. The thicker braid doesn't cut into the kelp or see weeds as easily as the thinner braid (especially if you use a short 1.5m mono leader) Braid with a diameter of around 0.42mm casts crap on a smaller grinders..
Distance isn't a factor for me, if I can get to 100m mark on the setup it's fine. If you want to cast far with small baits and a light sinker a grinder is better. However, I'm looking to fish with 4-5oz sinkers, really just because I don't want the bait to wash out of the strike zone to easily. To fish a 5oz sinker I wouldn't go below a size 8000 grinder, otherwise you are putting a lot of strain on your reel. That's also why I don't like to use the smaller multipliers, size 8-14, small gears working too hard if using heavier braids and sinkers. At the end of the day the size 16 multipliers (I'll be using a Daiwa 35H) just sit at the right mark of durability and performance. A big plus is also that added retrieve speed of the bigger spool. I cast comfortably with multipliers so there is no real issue for me in terms of ease of use, especially with these smaller reels.
Just a tip for the guys using the multipliers and braid. What I have found helps a great deal is doing a zig zag at the end of the cast and end of the retrieve. So once you have casted and taking up the slack zig zag the line in an exaggerated manner with your thumb across the spool. This helps the line digging in if you get stuck and also helps that the braid doesn't jump up towards the end of the cast. Then toward the end of the retrieve, say last 20m, zig zag again, this helps to slow down the spool on the first part of the cast and just helps with an overall smoother cast.
Fly-aholic
Hi DJP,
Now the zig-zagging is interesting. I will have to think it through.
DJP
The zig zag really works. Also, if you get stuck and need to break off just role some braid of the spool and and zig zag it back up under tension, no issues on the next cast.
The zig zag at the end of the retrieve comes from casting big size 50 multipliers with big baits. I don't know the exact science behind it but it slows down the spool on that initial part of the cast which helps one control the spool speed. That way you don't have to brake the spool too much mid cast. It probably reduces the potential distance of the cast a bit but it definitely helps to avoid those backlash overwinds.
Fly-aholic
Never thought about it that way but makes sense. More line coming off initially per revolution and the delta in circumferential speed from stand still spool to full speed is incremental.
Yes, second the zigzag...I was taught that too for spinning, when you dont get the nice even side to side line lay, the next cast you are far more likely to overwind in the throw...at the same time in an strong onshore etc..it helps to exaggerate the side to side motion of the line lay to slow the line down coming off the spool. It is just muscle memory and second nature to me by now. Even when doing a normal line lay, it helps to every few side to sides, do a quick zigzag or 2 and then carry on as you were and maybe another before done retrieving, this just ensures that next cast there are a moments or two where the line flow is just automatically feathered for you..like touching the spool with your thumb. Between that and a magnet i hardly touch the spool except to feather the line before the sinker or lure hits the water.
Ja but what a difference one little hidden magnet can make..and the newer age softer tip, thin blank and thick wall carbon composite (I think the 50% composite best for me) blanks, are where it is at for casting multipliers. My rod builder said that to me a couple years ago and I trusted him to build me a rod and I have not looked back since.
Fly-aholic
Seeing that I have fished multipliers intil 2 years back, I have never heard or observed this technique. Where have I been the past 45 years?:doh
