GARDEN ROUTE
Def-e-nition
My rod , in the Meantime , had also gone off , And allans pal had picked it up and done the honours of pulling in the fish .
 I Must say , i don't Often Like campaigning some products all the time , but, since i first saw the Stuff in october of 2009 , i've Liked It . and with good Reason .
Slides Love it too .
hennie Papenfuss edition sea Grand .55    silky smooth , and on the saltiga , a joy To cast .who Cares about abrasion resistence when it casts and slides so Nicely .
So.
Today , we'd been having Ittttt , and Out comes a soupfin .
 allen gives it The oog , and i Can See him turning it into chopped portions like That raccoon Thing on the BArnyard video when he checks out the chickens , but i told himm Id Rather get another fish Tagged ,and so, because of a small piece of yellow plastic with a number on it , another shark's Life Is saved .
This had turned out better than i Thought . jinnnnnnnnne .
He Kept edging Me On to go for broke . I Was hesitent , and i Mean - how Often is it one tries to beat The odds , and not Only target, but also to actually get what you were Looking for .
 Well .
Here's the go-for-broke Bait .
I could smell the ammonia a Mile away .And so would "he"....
Def-e-nition
Ad break !!!!!
SCORE - Last Longer
 Lol  !!
 funny as hell . Cheap too . same colour as urine but tastes better .
apparently ..
Def-e-nition
I walked all the Way to My right , and let Out the Monster ammonia bait , shaking it for ages to ensure That it Made it's way all the Way to The bottom .
 I Was taking No chances .
None .
It Was probably half hour , maybe 45 tops , before i saw what looked like a wave nodding the tip of my /8 . Or was it just a wave ....................... I ran to the rod , and when it made another bounce bounce - i Knew - hier kom nou groooooot K !
BAM .    who's your Daddy ?  0 -   140km/h 7 Secs Flat .
The Eastern seaboard was Now On the other end of My Line , and running away with the bronzie head in his mouth straight out to dana bay . I gave him line to make sure the circle found it's Mark , did a 5 count , tightend the Drag .and Struck .
Immediately , as if instinct told it the way forward, he turned and made way for The point .
 anybody remember Frans ???????  yea- headed straight for the Same point , only problem was i was more Lef tthis time , and he proceeded to swim indescrimanteyly into all of the other guys lines ....
 with .60 big game on , i really wasn't scared of Pulling too hard , or being cut  off easily .
allan grabbed the rod while i tried to Make way to a high point . I thought if I Manouvre Myself to higher ground it Might give me a chance to actually land This sucker . it moved Fast .. damn ........
I Stood at the top and bfore allen Could hand Me The rod again , we Decided to dead Lock him and pull The bugger in a make or break .
It Was to be number 2  ......
Allen got him to turn briefly , and then he breathed in , took a sip of his own SCORE  Drink - and pulled off all my Line down to the braid Knot .
ALlen dead-locked the spool with his thumbs , and for a moment it kept going .he thought he had it stopped , when the frikkin SWIVEL on the slide , parted.
 i have made slides without swivels before , but in the surf i find it sometimes Wraps em up too badly .
 anyhow , that was an expensive swivel .
 cost Me a freight Train .
Again .
Man , What a full Day this Was .    shiiiiiiiiit ................... i Was poooped . allan just wanted to Stay , i had had enough . The Saal is certainly no place to hook a bus , and if you do, you better have Abs brakes  to stopa That thing from going round The corner , or it's bye bye foooshie ...
Def-e-nition
And as the Sun sewt on another Magic day , i reeld In the Last bronzie fillet , And called it a Day .
i think my back will have recovered again in a couple of days  or so .
Psy
::S
Ag nooit my broo....best remove the swivels when next at frans~se~hoek!!
You think it was ole 'Frans'? or something more streamlined than a stealth bomber?
looks like you had lotsa fun anyways ::S
robyosh
Okey now that my wisdom teeth have been removed now I need to
get a toothy bugger to take revenge on :ssswim: and this ain`t going to be done with any anesthetic so as JAM would say the gala is on.
taahirG3
Hi Robyosh
Need some help..
Going to be staying at the wilderness beach hotel in January next year .
I normally fish from from right below where I stay…and then to the left at flat rock where im always successful with Kob.
Where can I fish from knysna lagoon…any advise….and what can I expect to catch
robyosh
Go and try the train bridge heard of some nice garrick coming out there knysna is a wonderful place but you just need to be in the right spot at the right time tho as every where else
Inky Squid
Active member
Knysna lagoon is a very big system and it's best fished from a boat, but there are a few spots where you can be successful from the side. The spot below is where I have had most success from the side.
Psy
taahirG3
Brenton on lake....take a drive turn off left before Knysna and take the road to Brenton. Left down to the lagoon and park close to the water, take a short walk toward the heads along the grass edge and you will find the Brenton channel, produces Wrasse, Grunter and Cracker. Early morning you may get Elf.
Mud prawns, skiet-kappers, bloodworm are best, live bait plenty, take your thrown net.
Stywe lyne
Psy
Better still is Ashmead channel....down towards the Heads on the cement rd, turn off at the cricket field park and walk the grass toward the island, throw for grunter and steenbras, choose your times of the day, most productive times are early mornings and early evening.
Tighter lines
Psy
Cob: 64.5kg
Yamaga Blue Sniper 100h
Shimano Sustain 5000
30lbs Jigman
Duel 60g spoon
20lbs Flouro leader
The fish was only weighed 16 hours later so could have weighed a little more when it came out of the water.
Sharky007
Inky Squid wrote:
Ek vang lekker vis die laaste tyd, so 3 tot 5 visse per week, so: ek kan nie kla nie ::S
Wat vang jy so lekker en waar? Wanneer laas het jy 'n mooi haaie geland. Ek hoor die raggie pups begin loop en jong bronzies. Behalwe die wat Beertjie gevang het...
