Galjoen Gurus
Jazz
All great posts guys, I've fished CP area pretty regularly for the last 4 years in all sorts of conditions and have a smashes on days where I thought not much was going to go on and conversly buggerall on what looked like perfect days and as a result I'm a firm believer that some days the fish are just scarce of non exsistant ,maybe feeding a few km up or down the coast at a new hole that's opened up.
I do how ever have 2 things I try mix up a bit on days when the action is very slow. 1 length of hook and sinker traces. I usually start off with a 20-25cm hook trace and a slightly shorted sinker trace but will go as far as a 40cm hook trace if nothing is happening and I've had a few days where that has changed things in my favour.
The other thing I do is mix up my sinker weight, going lighter and allowing my bait to wash around a bit more actively or on days when the under current is pretty hectic go heavier allowing my bait to settle in one spot for a longer period.
No guaranteed to catch fish by doing this but definitely helped me out on a few occasions when there was a major blanking on the horizon.
BigBen
Seeing this topic is related to Galies..
Here's a number of rules I apply.
1: Never fish too long in one hole.. If after 5-8 throws no fish move to another spot. Sometimes you'll find only a few fish feeding on a reef(small)...With Galies you gotta stay on the move.
2: The myth that Gallies feed only on a rising tide is bull...Any working water high or low will produce(Bait depend at most times.
3: Never fish with 1 type of bait..Gallies are also uitsoekerig( I stick with 3 baits mostly..Mussel incl black, Prawn, Reds(preferebly sand)..Fresh or stink...
4: watch your casts..Most time people cast over the fish... like to cast in the front(towards me) of a reef as food washed loos will wash towards you. Gallies swim over a reef and back again to deepish water to find food.
My $
grootvis
JD wrote:
I have never caught a gallie at CP on redbait, mussel and worm yes.
True, its probably the one place on earth where it doesnt work as well, if ever. I must however say, I witnessed probably one of the biggest galjoen ,at misty cliffs, get pulled out the beach infront of the houses, on redbait! I tried and tried with redbait, gave up!
Cuban Cigar
stinkmossel wrote:
i agree with grootvis. on occasion i would fish one of my regular spots, with no luck, and as soon as you move around and find a freshly open hole, you would have a smash.(gallies).
all the fish in the area would be actively feeding in that hole.
water temp dropping to quickly(falsebay especially), affect gallie fishing in a huge way.
Great info all around !
I have to also agree on the water temp issue - from Falsebay all the way to Blombos, my own catch records of the last 13 years, very clearly show that I have a much better catch rate with the gallies, when the water temp rises above 12 deg and up to 16 deg, than when it is lower, with a substantial drop when water goes below 10 deg.
I write down the water temp on my ORI tag cards and when I now look at the total results, it is very clear to see that all other factors like baro, wave height and wave action, wind strength and direction, moon phase etc taken into consideration, the end result of water temp in the higher range, spells good fishing !
BigBen
So true, and yet we refer to Galjoen as a Winter fish when the water drops to it's lowest at best...13-15 degrees werk altyd vir my
grootvis
My $
benna,
All those points you mentioned are spot on. Galjoen swim in shoals, and move off very quickly in shoals, if it gets quite, move, you might find a hour or so later they back there again, not that they went off the bite , just kept swimming around.
Bungi
Awesome information guys.....Zane does this all make better sense and give you insight as to how these fish behave.
Can we know start a similar thread about women (LOL)
.When do hey bite the best
.Does baro pressure effect their mood
.Moon fazes.
.What bait works better........
grootvis
.Moon fazes.
Yes, then we publish a new "galjoen" book titled "vroumens, Onse vis"....:hyst:
grootvis
.Moon fazes.
Oh, and dont joke, ALL water in any form is influenced by the moon, do you know women have much higher volumes of water than men? .I think we ok for now, its neaps isnt it.Self explanatory and definately makes sense, but better stick to the thread!
Blaasop
Zane wrote:
Thank you for your feedback forum members,
The strange thing is that when I fish Cape Point Reserve or the Hangklip Betty's Bay area I normally fish during the foulest, biggest cold fronts.
It does make sense though that we had a number of big fronts this past weekend, however the weather conditions were consistent with at least 3 days of solid NW to SW winds with BIG swell, normally a winning recipe...
Tight lines
Z
Sometimes, notwithstanding the fact that the weather is still foul, the main part of a cold front has already moved on thereby causing a rise in the barometric pressure. That is probably why the fishing conditions improve.
Nowadays I find myself relying more and more on what I see (pressure wise) on Windfinder before planning an outing.
On the udder hand Darren, if I get an opportunity, I go fishing. They still remain enigmatic creatures...always full of surprises.
stinkmossel
for the new guys, its probably easier to keep it as simple as possible ne.
the basics...
most poeple forget the most important thing in a good gallie fisherman's arsenal...
and that is water reading.
im talking fishing off beaches etc, about identifying holes and banks,(newly opened).
i guarentee any aspiring galjoen fisherman, learn how to read the water, and you will start catching more fish more regularly...
later on you can look at a stretch  of beach and literally read it like a book.for example:
swell coming in,(size etc)
breaking over and against some reefs.(that will create a nice wash and a rip in stronger water.
which way is the rip running? the rip will be a cleaner patch of water with hardly any sand in it.(it basically flows like a river)
normally the direction of the pull in the water changes from high tide to low tide.
that WILL determine where (against which bank/reef), your fish will hang out.
how deep is the gully, ?(is it a high tide hole or a low tide spot.
is there still sand in the gully.
NB-how long has the hole been open.
etc etc.
all that comes together with one thing only...time spent at the water.
and again, that is the fun part...
the rest of it is fairly straight forward.
doesnt matter what bait you are using. if there is gallies in the area, and they are feeding, then they will nibble at your bait. if they like it, they will take it..
if they dont like it, the wil bump and nibble the bait, and move off.
so, if you are not getting any bites, it doesnt mean that your bait is wrong. it just means that you are fishing in the wrong areas. which comes back to water reading/predicting.
Henlie
Everything in this thread mentioned is very true but I would like to add something i.c.w water temp. Watch the wind direction a day before and on your fishing day. Wind direction determines the water temp.
grootvis
the basics...
etc etc.
Excellent! you absolutely right, I think we take for granted that we can read the water, but not others starting out, it is actually the Foundation of all this info!
rofflign
grootvis wrote:
Here's another one for you guys, I know I will get alot of negative comments about it, but it has certainly worked, I still dont know why exactly but it does, and I will definately vouch for it. Especially gallies, I have caught hundreds of gallies in cape point, Pslaterix will confirm this, now, do you guys ever read the Stywe lyne magazine? if so, you will all be familiar with the "best fishing times". Each and every time, conditions depending, if you fished for gallies on those days, you could catch plenty, the real dik sessions, on other days, you would catch, but they certainly were not as committed and in numbers, this happened each time I fished on those days, and to this day, i still try plan my trips on those days. I know everyone has there perspective on things, but for me, these days are spot on, and it does work, and as we were saying earlier, its related to moon phases, so just keep that in mind, try it out, and see, but obviously you must have the right conditions to start with in the first place.
To true.
rofflign
100% and he did mention the wind was changing from NW to SE.
Bungi
Lekker info guys.......really informative and interesting.
I have also done a lot of spearfishing (mostly Stilbaai). This has taught me a lot by seeing how things work below the water level. Its quite amazing to swim over a stretch of reef (200m long) and find nothing.....then all of a sudden you get one spot that is just teaming with fish (for no apparent reason....that I can see)
We also find most of our BIG Galjoen and musselcracker swimming on the land side of big exposed rock or rock formations where the see has carved a hole. When I cast I always try and get as close to the back of a rock that is exposed in my fishing zone.
BigBen
100% correct....Precious info to know
grootvis
I will attest to that statement, thats how i target my cracker, thats where i catch them, i catch them on the sand.
