Galjoen Fishing
justin88
Good Day mates
I am keen on becoming a Galjoen fisherman.
I am unsure though as to whether I would need light or heavy tackle.
Any advice would be appreciated
steveaf
I am no pro...... However what I have read and seen of Galjoen is that the fish has a relatively small mouth and you won't really get specimens larger than 8 KG makes for light tackle. I have caught a couple of them always on light tackle with small bait. They fight like crazy on a 7 or 9 foot rod.... Can be a lot of good fun….:fishn
Koper
I'll say a good all rounder setup to start with will be an Exage 110H (one for sale now by Ebs), and a reel like a SL30, Tor 14 or Fathom 15 (sorry, had to mention the fathom otherwise Strepie will send the lynch mob after me:fbash).
Seriously though, all of them is a good reel to pair with the Exage 110h.  Search for info on the 110h, a lot has been said about this rod.
RINEX
"Skurf" raised this topic the other day when we stood on the reefs.How you define "light tackle set-up"
1.10/12ft rod ? (rods that these days host 5/7oz sinkers)
2.Line diameters and strengths ?(80lbs casting braid)
3.reel size (Strepies toys that fly easily more than 100m)
4.terminal tackle
From my point of view :
Galjoen is known as a fish that you can catch literary from even 5m from you.So having "heavy" equipment is in some cases unnecessary.
Galjoen baits to use are small ,so again "heavy" stuff not needed.
This will differ from location/spots of cause as you may find at some spots where the holes and gully's are far and then your 10/12ft rods lack a bit where the 13/14ft will be the correct ones to use again.
On the other hand,fishing with Galjoen baits in deepish water,(Southern Cape onward to the East)in search for Galjoen you might run into Mr.Cracker and then its prayer time and the pity that you dint opt for the heavier stuff.
Do your homework correct and see what will work for you in the territory you going to fish.
:fswim
Strepie
Also contact Kaspaas for one off the SSEC Galjoen clinic cd's. A wealth of info there regarding all aspects of galjoen fishing!
JD
My 2c .... go light, galjoen has soft mouths and its easy to pull the hook out. Lighter tackle forces you to be gentle. I think this is why Dreamer always catches more than me.....:fbash
stinkmossel
If you are unsure of the tackle to buy, I would strongly recomend the loomis 10ft. New it wil cost you around R350. Its a awesome little gallie rod.
sneaky ninja
i use light tackle. a 10ft rod and size 50 coffee grinder. 10kg braid. does a real good job. iv found that you only need a 2 to 3 once sinker for most of the time. and as to holes that are far away with my current set up i can cast bout 100m quite easily. and anyway all the gallies iv caught have been within like 50m of were i was standing. hope that helps
PatrickC
I bought an Adrenalin 11ft a few weeks back for about R650 from Alpha Pro. Its a 4piece, 3-4oz and 4-5oz tips with tigger grip. Very lekker rod! Would recommend it!
