Hiya
Your transducer is mounted too high. When you start moving faster than 10knts, the boat gets onto the plane and your transducer is most likely out of the water. Once it gets air below it, it'll not read properly. Try mounting in lower. Be careful though, becuase if you mount it too low, it'll create drag and can possibly break the unit off the back of your boat. Read the installation manual that came with your echo. It will tell you EXACTLY how many millimeters the transducer should be positioned below the hull.
I have mine inside my hull and it reads well up to 30knts. Realistically though, you'll only need your fish-finder at under 10knts, as when looking for fish or bottom structure, you'll generally be travelling very slowly. Same as when you're trolling.
miles
