furnace i build
manne man
I took a 300mm piece of 8'' steel pipe 10mm wall welded in a bottom ,
30mm inlet for air at the bottom side. Made a loose top with a 50 mm hole
to place on top , conected a blowerfan to the inlet for air. Fired it up with
coal and diesel , do it outside smokes a lot when starting up. Make a
melting pot to put inside and brackets to rest the pot on. I dont know
much about this stuff but just tried it as i like to do things myself . I made
a few snoek spinners used steel how do i make a mold? i used plaster but
did not cast any think it will break after the first cast!forgot to say get some boilerclay and cover the outside about 20mm thick put a piece of thin sheet metal aroud it and rivit in place
