Flippy has made me think.... I was under the impression that the spine of the rod was on different sides depending on whether it was built as a casting rod or spinning (with "coffee grinder"). There is also a definite difference in placement of the guides. How do you overcome these issues when you build it as dual-purpose rod?
With regards to the suggested guides for my 300/2 scratch rod project... I have taken note of both -aholic and Craig's suggestions and it makes sense. I haven't been able to watch that you tube clip yet, Craig but will definitely do. I also like the suggestion of using the KW and KT combination. Will nevertheless also chat to Chuck about it when we get to actually building the rod.
What Top would I use with such a set-up? Maybe the MN Style (BMNAT)?? Size??
By the way, my main target species would be Galjoen, so it is going to be rocky areas. Not too heavy braid and leader of max ,50mm. Mission is to get as light as possible, yet not be concerned about something more ferocious than a Gallie taking the bait! LOL
