Free boat plan
Dam Duiker
I am in need of a boat plan/drawings for a flat bottomed boat something like the American airboats or swamp boats as they are called. I have 8 sheets of new 6mm marine ply which should complete a boat of about 4.5m long. The idea is to have a flat wet deck almost the height of the boat and be able to spin cast all around the boat and not have to climb over seats etc.
Please guys I honestly need help on this one
Dam Duiker
Thanks for both sites boet. I went through the 2nd one earlier today however I find the 1st one more financialy suitable.
Shannon
If you are looking for a flat bottomed boat that can achieve decent planning speeds then you need to look for Jon Boat plans.
The first plan submitted here is nice but is a displacement hull and not a planning hull.
You need to specify what you want the boat to do.
6mm sheets of ply are fine for hull panels but are not thick enough for stringers , bulkheads or transoms.
I've seen so many guys make this mistake, they want to save R500 on a good set of plans and then throw thousands of rands at a build that probably won't work.
Buy a good set of plans like the ones from here http://www.bateau.com/
and then atleast when you get to something that you don't know how to deal with you have the forum to help you out (Trust me you will need that backup).
Dam Duiker
Shannon, looking at the build and quality of your project I have to take your advice.
I actualy only need displacement because to me angling and speed are 2 different cultures. I will play around with the site you refered to and see what they come up with.
Regards
Bux
I was toying around some time ago and downloaded a small program from these guys, wich allows you to g=create your own boat and even gives you the sizes and cuts of your plywood when you done. use it or not, but its great to play around with.
http://www.hullform.com/
Dam Duiker
Bux this is very useful information. I have made the download and will play around at home tonight. Many thanks boet!!
Dam Duiker
Managed to pick up a speed boat this morning without motor and trailer which is not a prob because I have both. The idea is to open it up, make up and install the marine ply internal sections, fill up with PU foam and fit a nice deck. It sounds easy but it is a helluva job which is quite costly. The nice thing about it is the hull that is perfect for what we need and also very stable.
