Big Kahuna 2
Found this Dvice on one of the local forums anyone using it and how successful is it?
Use of DVice
The Dvice is designed as a “Hookbait delivery capsule†with its primary purpose to deliver delicate baits in a good condition at long range. The DVice has a home made feel and is constructed using a plastic tube that contains a self fashioned weight at the base, with a screw thread for attaching Gemini Lead Fittings. Attached to the weight is a piece of stainless steel wire that is fixed into the weight and through the tube at two points, making a rigid construction that is tough to break. It is designed to replace your conventional lead on your rigs.
The product works by protecting the baits inside a plastic cylinder during the cast, Once the Dvice enters the water; the water floods the plastic chamber in a controlled fashion thus ejecting the bait at a speed that is unlikely to damage it.
Use of DVice
