Foulhook Gallies
Wolmossel
Hi Gents,
I use a normal sinker trace 50cm & Hook trace 40cm with & without lift. But lately I foul hook 3 out of 4 fish. Hook sets under the head.
Is my bait presentation to long meaning the bait itself eg. 4-6cm or is it coz the fish take the bait not on the hook side but higher up the line?
GVT
It is strange to me that it happens that often, but then again Im no gallie expert.
With that said I think it is very possible that the fish like you said is taking the bait higher up the line,as appose to taking the entire bait.
What size hook are you using?
Try a smaller hook maybe and smaller bait.Hope it works. Atleast you still landing a fish and not loosing 4 out of 5.
stinkmossel
tubs the sea saver wrote:
I had the same issue, i just delayed my strike a bit and got more mouth hook ups also i make my baits thinner
correctomondo...
long thin bait normally gives you a better hook set.
maybe you should try sortening your sinker trace by a third.
what hook size/brand are you using?
whalerider
Are you securing you bait with a healthy dose of cotton around the shank ? if the bait is long or even blob like ...and the cotton is tied loose , there are chances that fish might nibble off the bait around the J of the hook and the rest of the bait lips up the line , Chokka is a prime example, if its not secured with cotton and a tooth pick through the hook eye , your bait will be sitting pretty by the swivel ! so chances are that your bait is wrapped around your line with a bare hook and you feel a bump...and strike ..you will have a solid hook up
Simen
My opinion is that is quit a common phenomenon A lot of anglers have mentioned this before and the real explanation for it has not been cast.
The best so far that most agree on is the strike time (for those who strike)
When feeling a bite - dont strike - rather when there is a pull on the line
I will also agree that Galjoen tends to catch itself, not really needed to strike
i also use a #4 mustard Hoodlum and always a flouro hook snook 30cm sinker snoot just longer than hook snoot, and i reel strike when i fish for galjoen.
Blaasop
I am also a disciple of the "non-strike" school. If I feel a strong pull, I just lift my rod. The only time I strike is when I'm catching strepies for bait.
BigBen
100% LIFT AND ROLL...
stinkmossel
wind him on.quickly..hehehe
some of those big boys, when the pull you flat, (on a 10 meter cast), you cant even lift you rod upright... love it.
The Rob
I agree with most of you guys. Not really necessary to strike real hard at a galjoen. Especially if the hook-up is not deep into the mouth, then you would want to work as gentle as possible. (But we don't know that until the fish is landed). But yes, please don't strike it like it's your last! Most of times it's not even necessary to strike.
Thinner baits usually also work better than big bulky baits. My personal opinion. Don't really go smaller than a 2/0 hook. I have also seen guys using small hooks, say a nr 1 or 2 and then LOADING it with the redbait. But I mean loading it. Again, a long and thinner bait works good.
If you struggly with your hook-ups as you mentioned, then try switching to circle hooks. You can get circles for R10 for ten these days and they do the job. Of course with the circles you will never strike, so should timing be a problem in your strike/hook-up then that would be elminated. It's worth a try.
Hope you land some big ones soon!!
::tight:
stinkmossel
circles shmircles..
if i can give a word of advise...
before trying to fix something that is not broken and changing to circles...
start using your J hooks like you would a circle hook..(similar).
your catch/hookup rate will improve. guaranteed...give the fish time to vreet..you will know when he is vas
Blaasop
stinkmossel wrote:
circles shmircles..
I think circles work well with big predatory fish. Bankfish...not really.
And I fully agree with the sentiment to allow the fish a good, hearty chomp at the bait. I think most guys get "bokkoors" the moment they detect movement at the end of the line.
rofflign
Bottom line like the guys say don't strike, it's usually when the fish takes that first bite and catches you napping, you then strike to quick on the next bite and foul hook him or pull the bait from he's mouth.
COBIA777
This is my theory why fish are sometimes foul hooked.
Sometimes fish are in an investigative mood. It sees and smells the bait, gives the bait a nudge and walla! A foul hooked fish.A very sharp hook with a proudly presented barb presents a strong possibility for a fish to be foul hooked when it rushes the bait particularly if there is competition to get to the bait first
Cob and Garrick are sometimes famous for this as well.
phillipherholdt
foul hooking a gallie is as Blaasop is saying. bokkoors! striking at the first movement you feel. the fish is starting to reach as i call it 'a frenzy state' and starts to grab the bait with quick bite and release actions. then the hard pull as it gets hold of the bait properly. i set the hook at the stage where the fish pulls hard and almost pulls you flat. then the 6.2.1 ratio needs to do its work.....;)
Muri
try use use hooks with barbs on the shank.. bait holding hooks for gallies.
Your bait wont slide up the line..
