For Sale
Geezer52
Hi Guys
I have two Okuma reels for sale.
1 x Convector CV45CS with .47 KFGA line.
1 x Contoura CR-453CS with .40 IGFA Triple Fish Line.
BOTH REELS SOLD
Regards
Geezer52
craigb
are these casting reels?Which one is the better of the two reels?Pardon my ignorance i dont know these reels.
Geezer52
They are both casting reels. The Contoura has a cast control and the Convector does not.
Other than the cast control, the reels are very similar. They are equivalent in size to the Daiwa SL50.
Geezer52
That's right. There is an adjustment knob on the left sideplate. The sl50 works with friction blocks which require the removal of the left side plate to remove or fit different size blocks.
Geezer52
It works very well. You can start off on number 8 (max 10) and when you are comfortable with that or you find there is too much resistance,you can go down a notch at a time as you get used to the control. Most guys end up turning the mag assist off after a while. It is basically a training aid.
The only drawback is the higher your setting is the shorter your cast will be, but as you get better your casts become longer as you turn the control down. It also prevents the dreaded thumb burn when trying to control your cast manually.
Geezer52
If your sinker is too light its possible, depends on the rod and sinker. 6oz is normally the minimum I would go on a 14ft.
