Keep you ATTx receiver in mint condition, whatever the weather throws at you.
The new ATT Cube is a dedicated waterproof receiver case supplied for use with Version 2 ATTx receivers that will not affect the receivers range or performance.[/*]
Audible receiver output is effectively relayed through a strong air tight case by means of a special membrane, and the housing is made from tough transparent material to enable you to see the LED’s light up.[/*]
The lid is fully sealed and secured with a positive locking mechanism, and The Cube also features a belt clip and a lanyard attachment point.[/*]
The Cube is buoyant, so if you accidentally drop your receiver in the water it will be easy to retrieve, and will stop the water damaging the receiver inside.[/*]
