MouseDog wrote:
Hi Fstander & MouseDog, I have just moved down to St Francis so I m new to this area and would like to hook up with some of you.
The " of a structure leading out to sea" you ref is this the Paradise old jetty ?:fishn
[color=#006600]FStander[/color] wrote:I tend to like the left side better, more sandy, quiete often you get some nice sandbanks that forms. Ideal for Cob.Herewith a pm to someone that's ask for info.
Paradise Beach is extremly productive at the best of times. I have encountered almost all the species that we get in and around our coastline. If you head through paradise beach past the old airfield and golf course on your right hand side towards St Francis Bay you drive until you get to an old entrance/launch site that leads down to the beach - It's just past the water tower - You cant miss it - From there you can fish on either the right hand side of a structure leading out to sea. On the immediate right of this structure there used to be a nice gully running through but beware you get stuck here quite often. Here you can literally encounter anything from Blacktail, poensie, MASSIVE sharks, raggies, blue rays, cob, elf, etc etc etc. The list is indefinate. Your terminal tackle should consist of a pyramid (sand bottom patches) or teardrop (rocky patches) Depending on your tackle I would recommend 3 - 4 ounces and if you use heavier tackle and can cast well up to a 6 ounch as the water normally has quite a drag left and right. Very clean chokka and pilchards works wonders and I use to even do swimbait from the beach there. I once sawm a 40 kg's bronzie and got busted up quite quickly, possibily by a nice Zambi. If the water is very clear as it sometimes gets try using mullets and other meaty baits. Secret - If you go over the lagoon between paradise beach and ashton bay look out for the pipes that lets the water through underneath the road - That's an excellent place to get big fat mullets - Using a fresh head cut just behind the dorsal fin will almost ALLWAYS get you action with the notorius HUGE gulley sharks there - I have personally gotten them up to 40kg's and beyond. The area that leads up to the Krom River is also very productive and if you want to do a bit of walking get as close as you can to the JBay side of the Krom mouth - Again an excellant place for Bronzies, Raggies, Blue Rays and even the occasional cow shark. If you are after pan sizes like steenies, blacktail, zebras and the like make sure you have some prawns. This is also a spot where you will find some good size Yellow Belly Rockcods
If you need any further info just shout and I will oblidge
Also at the Mouth of the Seekoei (Between Aston & Paradise) on the Paradise side is delivering great Cob lately.
