Foam and keel strip woes
JFE
My poor old boat kept taking water; R23,000 and 2 different boat shops later it’s still not corrected. It keeps on taking water through the keel strip, that was readjusted 4 times already, latest being a redo of the keel itself applying 4 new layers of fiber and refit the strip. But it keeps on taking water. AND of course with all the struggles going on the whole front side it now water logged and the foam saturated with water, so much that I have a real struggle to get it onto plane because it is so heavy up front.
Ok, so I decide time for DIY, gonna spend my holiday break to fix the problem myself, tired of paying good money to be disappointed. Started to cut the deck open in sections, remove the foam, seal the inner of the hull at every protruding screw point with epoxy resin, redo the foam with a surveyor present and maybe, just maybe my woes will be over. Ai the agony we suffer…………….
The mess it is at this time, and the sad part is the deck and boyancy was done last year Nov, make me want to cry!
Patrick
Here's my theory on keel strip screws. I think you might find that even after epoxying those screw areas you might still get water leaking in around the screws eventually. The reason being is that as the boat is repeatedly trailered it causes slight twisting/movement in the keelstrip which causes the screws to move, which breaks any seal around the screws. It only takes the smallest gap to allow water to seep in.
I had this exact same problem on my previous boat even after sealing every screw hole with what i thought was a good enough job.
Will have to create a huge block of epoxy around each screw i think so that even if you get movement happening in the screws and a gap forms it'll contain the water from entering the hull.
Best I think is to do away with the keel strip and screws altogether and fit one of those glue on keels. BFC I'm sure will have some good suggestions too.
Also make 100% sure when you open that hull that there isnt some other hole or crack in the hull as well other than the screw holes.
JFE
benniejordaan wrote:
How much water are you talking about?
a lot, must have pumped more than 50 liter out as I've removed the foam. will post some more pics tomorrow as I've nearly clean cut my little finger of with the knive cutting it out.
And yes it does look discusting and a very poor job. Was done by Aqua Doctor in Middelburg, had to take it back 4 times for repairs but still a major ballsup.
You know, a good way to find a leak is before you cut the deck, put low pressure compressed air into the drain plug, pressurizing the hull. Then you check for where water or air seeps out. You can then also use a paint brush with soapy water to wipe everywhere looking for bubbles.
JFE
The sad story of my finger, cerated knife while cutting the foam, hurts but hey guess it's the price I have to pay hehehehe.
Bennie I've tried that route, but I have to remove the old foam, it's saturated with water and guess what, they never left drain holes so the water can drain out the back. Figure they were pretty sure of their job then. But for now I'm stuck, right hand doesn't want to work all that well so set back a day or 3 but hopefully I'll have it done by the 3rd when I start work again.
barryfish
JFE try a hand scraper, less opportunity for self damage. Need to find where the water in coming in from, are you going to re glass the whole keel from inside?
willem wikkel spies
that hull looks really bad.
interesting, that when i did my hull, they said that 1 layer of fibre glass was needed to seal the hull.
so grinding out all that ******* and giving it a layer.
i took the other option and gave it two layers before getting the foam done.
nigel boat did the foam and then sealed the deck with 1 layer fibre glass.
decided thats not enough and gave it a extra two layers.
i have not fitted the inspection holes yet as they almost always leak.
i wanna keep em water out.
