FLIPGUIDE
camo shorts
Easier to store in tube as it takes up less space.
with a multiplier reel when casting, line loops up, so flip guide has a highr position so less friction on line, further cast.
Think that's about it
BigBen
Mmmmm
I've seen guys cast 120mtr + without a flip guide...Do mean they'll/I'll get better distance with one fitted to my rod???
JJ Pienaar
And to add, it look's cool ha ha ha it's like rim'z on your car bling bling bro. . .
And it eliminates that flat spot u get when fighting the fish. . .
''Flat spot'': when fighting a fish and u put a bend to your rod the line is prone to touch the blank flip up guide eliminates it frm happening. . .
Moyeni
what I like about the flip guide is that your line has less contact with your grip which will cause heat on your "Mono" WHICH in turn means problems...
vvidevb
BigBen
vvidevb
Guys I don't wanna sound like a pesimist. But what the 'frikkedel' r u talking about.
'Blankspots? Heat abrasion?
I'm fishin' 4 almost twenty yrs without this thing. I've never seen a line break bcause of a blank spot / heat due to lack of this flipguide.
So u actually confirming this tho 2b a 'luxury addition' to a rod like a pimp my rod kinda thing.
Dr.Pinkfly
my bru,when fishing for biiiig fishies every little detail on rod and real must be pinpt in order to give you the best chance of landing your prized catch at the end of the day.. It has advantages but for edible fishing i dont think it makes much of diffs.. Just my 2c
Mangi
I actually believe it helps more to keep your BRAID away from your blank and grip while fighting a fish.
Any of the Big Shark Hunters willing to elaborate?
stinkmossel
just look at the cuts/lines on my grip and you will understand why a flip up is good. it cuts into the foam when you r rod bends/pulls really hard. getting mine done next week...
heat friction.. tke a 1mm leader and keep it tight. fold toilet paper around the leader and rub it hard on the line, it will brake before the 4th stroke.tolet paper/ foam grip, oilskin jacker..etc every bit counts
BigBen
I hope you guys don't mind all the ? I'm playing a bit of devil's advct.
If the above arguement is used. Then why doea u'r line not snap when a fish takes u'r line to 100mtrs and all the tention.fricksion on u'r eyes does not snap/part the line. U used the argument of 'toilet paper'
Dr.Pinkfly
you arnt rubbing the line on your eyes side to side now are you,like tp does. What he means is when not having a flip up the line can rub against the rod..now that builds up heat..
DJP
I have a flip up on the two R&S rods I use most. I must say that even with it on the line still sometimes cut the grip, but it is much less so than would be the case with a normal height guide. I've also redistributed the guides on the mid sections because with a flip up only two and not three guides is needed, less guides=less friction=longer casts.
Simen
Thats 100% right
Trophy
HIya Guys,
Two main reasons are the 'flat spot' when the rod is under load the height of the flip up keeps the line away from the blank.
But the biggest advantage for me is when casting the height keeps the ugly knots from hitting and cutting into my wrist.
I also thought it was all bling bling until after a few casts on my new Enigma Custom Rods and no more cuts!
