Fishing channels/ harbor mouths
Glassy
Had a day off last week and went scratching along the Bluff with a fairly light setup. Stopped at South Pier in the afternoon for a few throws before heading back and something big hit my bait. Whatever it was took off high-speed and pulled probably about a third of the line off my little bg3000. Managed to tighten drag and gain some line back after it slowed down a bit but then it stopped and turned and headed for the pier & cut me off.
So now I have put 50 lb braid on my big boss and a longer stronger leader and I'm going back.
Just wondering what sort of rig you guys think might work best for the spot. Been using small pully rigs with small and medium circles (1/0 to 4/0 with 2 or 3oz weights) with blob baits and they have worked well on the incoming tide. I will be parking on the rocks just before the pier itself as I have no permit to be on the pier. (See pic)
One old guy I spoke with on the walk back mentioned it could have been a skate so make I should go back with a heavier setup. I have an X-master with 40lb maxima and a 70lb ultragreen leader I could use with a bigger rod but I think the length may be an issue. Would using a 14ft be overkill? Maybe 12ft would be better for some leverage and ease of use/handling. Need to be able to turn the fish before it turns and heads for the pier again. Any suggestions?
