Fish not feeding on bottom
skompy
Hi
I went fishing this weekend and saw fish jumping and feeding and although I cast in that area was unable to get bite.
When I went out with the fish finder I saw that the fish were all about 1-2 meters of the bottom or right at the top. And I am thinking that its the reason why I drew a blank.
How will you fish this condition? I tried all the combinations of dips that I had and hook baits but had no luck.
skompy
Thanks for the reply.
I did try a couple of floats without success.
I got a copy of Supercast's DVD volume 10 and Loukie was saying that not all the dips and ball dips are created equal. Some will lay on the bottom and release slowly into the water like ox blood (which I don't have but will get before going next time) and others will react as soon as it hits the water.
I think that may be secret. The other question now it what will be the best dips or ball dips to use in this situation?
Maybe someone did some experimentation and can give some advice.
RHK_888
Interesting discussion. Most, if not all of us don't weigh the possibility that the fish are not on the bottom when carp fishing.
A while back I was cleaning out my box and chucked a few items aside that were coated in spilled dip and it landed in a bucket of water. I noticed something quite interesting. Some dips had no apparent effect in the water while some released a trail of "oil" and others oozed a long trail of colour going upwards in the water. So I took all my dips out and put a few drops of each into my unused worse for wear outdoor Jacuzzi and saw exactly what dips leave this magic colour trail. Now, I.m aware that dips releasing colour and scent is not new knowledge, but it was interesting to see how exactly dips create a colour and scent trail leading the fish to your bait.
Now back to the topic. What my little experiment could help with is deciding what dips to use to bring the fish down to your bait when they are not already at the bottom.
The dips that I found that leave a colour trail are:
FX
Ebony
TAC
and well,Basically anything with WINTERGREEN/FLORO/EGG YELLOW or any kind of water activated colourant in it.I would use quite a lot of it to create a bigger trail that lasts longer if I figured that the fish aren't on the bottom.(Bleeding floaties could also help in this case as it also oozes a trail of colour).
Dips that leave an "oil" trail:
Pink Panther
Devils Fork
Ox Blood
Special
Stuttafords
Gumtree
Perdeby
and the list goes on.
Most of these are your strong dips.
The "lighter" dips had no visible effect in the water which is no surprise as these are more your "takers" and not "attractants"
Banjo
Hasbeen
Legend
and a very long list of sweet dips that I wont type out as I'm sure you get the Idea.
Hope my 2cents helps.
Cheers.
skompy
Thanks for info.
I had the same idee of adding a couple of drops into water and see what happens. The info you supplied will make it easier for me._seal1_
D5
Lacost wrote:
sounds like they getting ready for sporning time
they wont eate now
I would agree with you . Been in similar situation hundreds of times  .
Fish is at surface jumping for some reason - and then no bites at all no matter what you do.
Weather or just wind direction changes  and here we go - fish is back on the bite.
RHK_888
I've also had times when fish were jumping and splashing then STOPPED jumping and splashing after I cast and my bomb settled. strange.
sfb
Google zig rig carp fishing. That way will be ur best bet if the carp are feeding below the surface. ::tight:
skompy
Thanks for reply. I had a look at zig rigs but they are to much trouble for me.
I had a change to talk to Loukie van der Merwe at the Supercast day at Extreme Fishing SA. He suggested using floro and strong and sweet dips to draw the fish down.
A couple of friends and I went fishing last weekend and we used this suggestion and were surprised at how well it did.
We added green floro to the Supercast ground bait and made it into balls and through it in with a spomb. We managed to catch 32 carps and one barber.
I will agree that it was warmer this time but the fish finder still indicated most of the fish were off the bottom.
We caught 32 carps and 1 barber using this method. This was the most fish any of us caught so I personally believe that there is some through to this.
maybe try this next time if nothing works.javascript:emoticon('::tight:', 'images/emoticons/tightlines.gif')
::tight:
Fish are coming onto the Spawn and when they thinking about Spawning they forget about eating.
I generally cast a good distance past where the fish are jumping, there where they are jumping and chasing one another they are looking to make babies and not eat.
Fish away from that activity to catch fish
