First Swimbait Attempt
Weasel
I had to use the modeling clay to seal and missed a spot....ooops!
Weasel
Just a full view off the final mould. Waiting to cure and ill post the completed lures later!
tauruck
Nothing wrong with what you've done from what I can see.
Did you use some adhesive to hold the plugs in place before you poured the RTV?.
Nice job, neat work.
:SSS
Weasel
Morning Tauruck.
Thanks bud!
I did glue them down but forgot one, that's why I used the scriber and clamp to keep the one down.
And so the divorce procedings starts in yet another place in the country..... Nothing wrong, don't worry about the oops, it happens.
Just one thing I've learnt, rather use POP for the first couple of molds, still gotta make sure those plugs swim right and it's way cheaper than using RTV right from the start, and once sorted (swimming action etc etc) then make the final mold of RTV.
tauruck
Weasel wrote:
Morning Tauruck.
Thanks bud!
If you use Vaseline around the base of the mould it seals runoff/seepage.
Weasel
LOLLOLOLOL My wife asked me last night if we going to build on to the house. Bathroom,toilet ect for the garage. Funny you mention it now.Good point on the POP. Never thought of it. Thx
T I read your prev post and im going to change to vaseline but wanna finish my EASY RELEASE first.
Thx 4 the pointer
That depends on what material your mold is made from also if it's an open or closed (two sided mold) and further to this is the size of the lure you're pouring (ammount of plastisol)
Open mold 4 inch stick-bait should cool off enough for you to release/remove say within 5 minutes (given it's the first lure, the more you pour the longer it will take as the plastisol will cool down slower due to the mold retaining the heat from each lure poured)
Closed mold 4 inch stick-bait roughly 15 minutes again the above applies.
These estimates are based on RTV silicone molds, polymers and fibre molds are a little more dicey as the thickness of the mold can cause it to cool faster or slower than the RTV.
