Fireline to Florocarbon
mark norval
Hi, can someone please help me? What knot can i use to join fireline to florocarbon, sofar I have been using a surgens knot 6turns I find it the least complicated the uni knot makes problems when looping the florocarbon because it is harder than the fireline.
Please help
Simen
I use a spider hitch on the fireline and then couple the mono in your case the FC with a Yucutan- You will have to experiment with a couple of these to determine how many turns with FC over the Fireline to achieve obtimal knot strength. Easy and strong knots. dont let these big names for them put you off.
mark norval
Thanks Simen that wierd name one works quite well.It kinda sounds like chinese vomit.
Will put it to the test tomorrow!!!!
Cheers:fishn
Simen
Mark some of these knots have more complicated names than what they really are to tie.
My advice- dont try and learn all the diffrent knots in one jump, rather take the ones you will use and master them before you know a little about all the knots. -you have to be comfortable in the way you fish.
camo shorts
I'm extremely lazy and have clumsy fingers, so I just use an Albright knot. Make a fold in the FC, then wrap fireline 12 times around the 2FC and 1 FL leg, wet and tighten. Haven't had any failures on 8lb fireline or 30lb braid with a 15lb FC leader, targeting steenies over the rocks at Derdesteen.
fishfinder23
Why dont you just attatch the fireline 2 a power swivel and use 40cm of fluro as a trace, works well for me! i join the fireline to the swivel using a cats paw knot, look in the knotts section, its really easy and a 100% knott...:wfish
eXtincT
I got two knots that I use for this. Excuse the quality. I did this in a big rush. Will post pics of the other knot tomorrow when i get a chance.
MikeF
eXtincT, thanks for that! Finally a knot I could learn to tie properly! Have you had any failures on big fish and could others comment on what they think the possible flaws in this know would be?
At the moment I just use the knot shown on the back of the fireline box.
eXtincT
Only a pleasure bud.
This knot was tested 6 times with 14 pound Berkley Fireline. When tied to a 13kg Maxima mono leader, the highest test obtained was 20.7 pounds, Only one knot tested below 17.6 pounds. So its a VERY VERY strong knot. You wont have any trouble with this.
Are you looking to rig for game and deep sea? If so I got another knot that works just as well but suits the longer leaders better. All terminals are rigged on extended mono leaders, which are attached to Binini doubles tied in the braid.
neilg
Spider Hitch to create a dougble in your braid and then 6 turn surgeons knot, hasn't failed me yet
nor has a double with the albright
also twisted leader knot hasn't either
stick to the knots that are the easiest to make PROPERLY in bad conditions (cold/dark/raining)
All 3 are good and EASY
Extinct, I see you've been reading a book on knots ....
