Fin-Nor 20
Hooked
Recieved my 20 from Whaler yesterday.
The reel has had Corbotex drag washers fitted from new and I am quite taken with it.
I bought this reel to use for edibles but on second thoughts its now my new shark reel.
In spite of it being smaller in size than a Trinidad 30 it actually has the same line capacity.I managed to spool on 795m of 0,38mm.When I get a chance this will come off and I will re-load with 50lbs braid and 0,50mm.The drag on this thing is immense.It is easily 40lbs of drag at the bottom of the spool (little bit of a overkill for edibles ).The drag is also smooth , there is no catching at all.
Whats really nice about this reel is its size.The reel is much narrower than a Tor/Tn 30.It feels really compact on my rod.
Whaler
Thanks for the good report! i still have a few of these reels for sale if guys are interested.
neilg
From Manufacturer site
http://www.finnorfishing.com/offshoreconv.html
VERSATILITY AND STRENGTH DEFINE THE ALL-NEW FIN-NOR OFFSHORE STARDRAG CONVENTIONAL SERIES, DEISNGED FOR TROLLING DEEP WATERS FOR RECORD FISH. A COMPLETE LINE-UP OFFERS YOU THE CHOICE OF TWO DIFFERENT POWERFUL AND FAST RETRIEVE RATIOS MATCHED TO YOUR STYLE OF FISHING, AND THREE DIFFERENT LINE-CAPACITY SIZES, WHETHER FISHING BRAIDED LINE OR MONO, THE OFFSHORE STARDRAG SERIES IS THE PERFECT CONVENTIONAL REEL.
THE OFFSHORE SERIES FEATURES A DIECAST ANODIZED ALUMINUM BODY AND SIDE COVERS THAT STAND UP TO THE HARSH AND CORROSIVE ELEMENTS OF SALTWATER FISHING.
THESE OFFSHORE REELS FEATURE 5 OVER-SIZED STAINLESS STEEL BEARINGS AND A HUGE STAINLESS STEEL DRIVE GEAR MATCHED TO A BRASS PINION GEAR, AND TOGETHER WITH MULTI-STACKED DRAG WASHERS AND A ROCK-SOLID ANTI-REVERSE SYSTEM OFFERS YOU INCREDIBLE STRENGTH WHETHER FISHING MONOFILAMENTS OR BRAIDED LINES.
FEATURES:
Diecast aluminum body and sidecovers
Machined aluminum spool
5 Double-shielded stainless steel bearings
Oversized stainless steel main gear
Solid brass pinion gear
THE OFFSHORE DRAG:
Constructed with 11 oversized discs of alternating carbon fiber and stainless stel, the drag system in the Fin-Nor Offshore Stardrag Conventional series is designed to perform at extreme levels providing smooth, consistent control throughout the duration of the battle, and for years to come.
SPECIFICATIONS:
Model     -  Line Capacity - Gear Ratio - Weight - Retrieve Rate
OFC16H - 350 yds. / 20 lb. - 6.2:1 - 23.5 oz. - 49 inches-per-turn[/i]
OFC20H - 380 yds. / 30 lb. - 6.2:1 - 24.2 oz. - 49 inches-per-turn[/i]
OFC30H - 365 yds. / 40 lb. - 6.2:1 - 25.0 oz. - 49 inches-per-turn[/i]
OFC16L - 350 yds. / 20 lb. - 4.3:1 - 23.5 oz. - 34 inches-per-turn[/i]
OFC20L - 380 yds. / 30 lb. - 4.3:1 - 24.2 oz. - 34 inches-per-turn[/i]
OFC30L - 365 yds. / 40 lb. - 43:1 - 25.0 oz. - 34 inches-per-turn[/i]
