FIgure Eight Problem
Def-e-nition
THe Line is forming a Kink Just above the Hook - I have tried all forms of permutations regarding this problem - I just cant see to get It Right ..
The old fashioned way of Burning the wire would solve this - But a lot of people have told me that this "knot" is sure to fail under heavy load ..Any truth ??
I also Notice the thicker Bloodwire makes a More prominent Kink IN the wire - Most annoying ..
so guys - What am I doing WRONG ???????????
Def-e-nition
Here's is the collar Method  I prefer - but Most guys tell me they dont like this when compared to the traditional Knot .
I happen to Like this method  though ...
Def-e-nition
ANother One showing the Kink In the line .
This part will end up in the sardine- but I find this Baffling as to why I am managing to do this every single TIME .
GUYS ?????
Help ..........
keane
Hi Def, maybe try making the knot further away from the hook and then slide it down. It could be that you are making your knot too close to the hook?
Mr H
Hi Def,
Try making the knot a little further back from the hook and then while holding the knot between your fingers slide the knot down to the hook.
I have found that if you hold onto the hook and slide the knot down to it then you are sure to get a kink in the wire.
only grip the hook and tighten the set up once the knot has reached the hook.
my 2c
Hooked
[color=#006600]Def-e-nition[/color] wrote:
[color=#006600]Hooked[/color] wrote:
Buy a crimp set !! The fig 8 in wire has never worked for me either.....
Failure Rate ?
 THanks dudo .
You were quick Off the Mark !!!!!!
 I was still busy posting and already a reply - Imopressive !!!
I have never had a failure with crimps , I was born without opposable thumbs so I cant tie knots to save my life , I always had kinks in my wire until I discovered crimps
Sylvester
Banned
You are using a fig 8, thats the problem. Trophy has an impressive instruction thread on tying traces with steel. do a search for it. I use a similar method to his and my traces now come out very neat, no kinks in the wire at all and most importantly no failures!
Def-e-nition
Thanks girls .
sorry I took so long - Been bloody writing exam for fire-arm license Renewal - $#^^#$%^#$%#$%@#%
took all Morning and most of this afternoon .
CRAP .
Ok - so figure 8 do higher up , but rathewr do flemish eye and twist the line around .
I Know Trophy's method is fail-safe for sharks n all - would the the collar thing one work for everything else ?
I know it sounds insane , but I am not the BIG lurky dude - so If it Biutes off - ahh well .
I just dont want to have a nice size cob by accident on there and it wrestles the crimp loose and Cheers China ............
Maybe I do some of this over the weekend at shark Platform .
Reefman, I believe you are flying down to come and assist in the refereeing of the event - is there any truth in the rumour !!??!?? c'mon ... People can open up and say "Ahh" on Monday Man . You make enough from 7 fillings to fly down one-time - with Kalula I mean .....
