With all the sards around I thought I would post this.
With the price at R5 - R10/doz. the Natal guys need to take advantage and stock up, but I often hear guys complaining that the fresh Natal sards don't keep well when frozen at home.
The only reason for this is because they take too long to freeze, the good commercial sards are blast/quick frozen and therefore still bleed when you cut them.
If you are lucky to have a bait freezer/chest freezer then all you do is fit a 12V computer fan (100-120mm) inside and let it run continuously and believe me your bait will freeze in less than half the time!! And when you get to use it, it will be much fresher!!
Another tip is to spread the bait out - those stackable A4 letter trays from the office desk are ideal as you can fit up to 10 sards on each tray.
