Setup for grinder different to multiplier or are you going to use it in multiplier configuration with a bionic finger? I'd use a size 8000-10000 shimano reel to balance one of those rods, i used to use a sustain 10000 or finnor lethal 60 on mine. A battle 5000/6000 is about the same size reel. That rod is a bit too heavy for scratching maybe, I use mine for cracker fishing off cliffs and livebaiting off cliffs and points etc..or use to use it for heavy spinning. For scratching i prefer something a little longer not much but that bit longer for distance, and something more sensitive which the 11ft exage heavy is not. But if you need to skulldrag a fish up the beach it does that well!
