benniejordaan
barryfish wrote:
wont need much more than this.
It wont be a compressor just a blower like they use on those jumping castles. Cheap... Would you rather have an air blower or a marine grade stainless steel pump to pump salt water?benniejordaan wrote:
I got how it works with non return valves etc, just why pump air, why not just pump the water out, with a one way air valve that lets air in and only pressured air out, then your pump can sit on the key, and you would only need one pump. when you pump water in will pressure the air and expel, when you pump water out you create vacuum, sucking air in.barryfish wrote:While the pump is running all you will see is it is rising. When it gets all the way up, air suddenly starts coming out the bottom. That is because air is pushed in the top which pushes water out the bottom. Once it gets all the way up and water has been completely expelled, air starts coming out the holes and it is switched off. If you keep the valve closed and dont let air escape, it stays up. Then you need to use a different valve to let the air out again because of the one way valves. I would personally just have a switch over valve that you can open/close instead of switching the pipes over. There will be a one way valves like a blow up mattress. One valve for up and one for down. In the video there are 4 pipes one for each of those inlet boxes.Anyone know why they pump the air?
My logic says when you pump out the water air on a valve will replace it, when you pump in the water it will get heavy and sink? or is the sponson under air pressure? would higher air pressure make it float better, or have i just answered my own Q.
Along those lines...
I think there will be 4 air pumps.
The air must be forced in to lift the boat? compressors involved?
