Echo Sounders
Flamingo
Please help, if I add another sounder on my boat, will the transducers interfere with each other?
I have a Garmin 525S and want to add another of different make, Lowrance or Furuno.
Does any one have a setup like this?
Hammertime
If you run both on dual or both on 50 or 200 then you will have a problem.
I run one on 50 one on 200 and that way there is no second echo or cross over. I must admit I only use the one nowadays as the cable on the other one got buggered up. It is there now as a spare as I can swap the cables over and use either one from the working cable.
