Dropshot gear
Fila se vis
Hi Guys
Being a student and all I finally did it to my wallet and bought myself some dropshot gear! Luckily I already had a small koffie meel so only bought the rod, a 9 foot Shimano rod, I am stoked!!
Then from what I have read I knew that braid is the way to go, R500 for 300meters, WHAAAAT!!! :fbash
My question to you guys is, do I have to use braid or can I use normal .3  6kg breaking strength line with a good leader attached to it?
Looking forward to cathing a kobbie on dropshot in Struis baai::S
Thanks in advance
Philip
Speedmaster
In my opinion braid is over rated. It is more likely to tangle and knot. I use normal .3 line on one of my reels for ds and it works perfect. If you like to put on some braid, try and get Spider wire. Is a nice braid and not so expensive. Think it is about R150 for 300yards.
PatrickC
Braid is worth it imo. especially for DS. braid also lasts a lot longer than mono.
Still not the expensive part... hard plastics, soft plastics, jig heads, spoons, plugs... thats where it starts to really hurt the pocket.
Fila se vis
I luckily already have a few of the above metioned..
Thanks for the info guys, hopefully I will be able top post some nice pics soon!!
Tight lines
ruanespach
Ja Fila, gebruik maar jou gewone nylon. Ek het onlangs braid begin gebruik en jy moet nie in die begin dink dit gaan "super amazing" en "unbreakable" wees nie. Dis baie nice dat dit so sterk is vir die dun deursnee, maar myne ravel uit (die individuele vesels vleg uit mekaar uit) en die dunner braid (0.1 mm vir +5kg) krap maklik teen klippe en goed af. Dit is seker maar "teething problems".
Braid is darem vrek duur en die kunsaas wat aan dit vas is net so baie.
VenterBJ
Wat n slegte dag by die hawe waner jy drop shot doen en kom 3 ouens en gooi hule lyne reg langs jou lings en regs, om te hoop jy vat pad want hule wil da vis vang. Wat se soort mense is hulle, ek het paar keer hule lyn uit getrek en toe begin hulle my vloek en en en. En hulle weet hulle kon n kans waag omdat ek alleen was. Sou hule dit gedoen het as ek saam ander daar gevang het.
For repetitive casting like required in dropshotting get a better quality of Spiderwire than the EZ braid. EX Braid frays apart with a lot of casting
Get Jerry Brown 20lbs (is 27lbs actual) It is equivalent to 0.18mm monofilament (compared to 0.30mm 14lbs mono)
Which one will you cast further?
Braid is more direct and sensitive in terms of transmitting the bite.
Hooksets more positive
Don't over fill the reel and the braid (quality braid) will last you as long as the lifespan of the reel or till you get stripped by a big fish.
Right rod, reel filled correctly, bob sands knot to a mono leader and you'll have endless hours of fun
20-30lbs braid for casting shoul not cost more than R250-300 and it will last a lot longer than R300 of mono for repetitive casting and retrieving
ruanespach
I've also found that the EZ braid frays when its lost its wax coating. It should still be fine as long as the individual fibres are intact, shouldn't it? I am also using 10lb Sufix Performance braid on a small Shimano reel and it also starts to unwind. The 10lb really is as thin as thread and I'll only be using it in very clean water situations from now on (no sea weed, lost a buctail jig after the first cast in weed at Strand).
I was actually considering the Sufix 832 braid, which is a bit thicker for the same rated strength and might take a bit more punishment. I'm also considering changing my leader setup (I'm using +- a rod length, but I don't like the sound and feel of the knot running through the guides). I dread watching my lure fly off into the distance with no main line attached to it.
Just as you get different lines for different uses so are different applications. Just as there diFferent values of lines as a result of construction methods and materials.
As soon as bonded braids come apart you must strip the fraying bit off and retie further up in the line
Braid's strength is provided by the dyneema fibres but there are other materials braided in to provide integrity and robustness and all other properties.
Suffix 832 is designed for repetitivE casting ie Dropshot as is Jerry Brown and Power Por
Fireline and Nanofil are thermally bonded to make them even tougher.
Whiplash is thinner with more Dyneema per volume making it a better backing and mainline for bait fishing.
So braid is not just braid there are braids for different applications
Wastage in the manufacturing process of thermally bonded braids as well as the long and technically advanced process is why it costs so much
My choice for 10, 20 and 30lbs for spinning would be Jerry Brown, Power-Pro, Suffix 832
