Drop shot techniques
Chris1
Hi to all the Pro’s
I have 2 Drop shot questions for you.
Question 1 :  When you drop shot for small reef fish (Black tail) in the surf, in a active gullie, you,  sometimes use a plastic fish.
Now! What action do you use for that?
I’ve tried it, and every time I get stuck on the rocks and grass. Wesley (ESA) said once, “You use the wash of the current for action”. This can’t be the only way.
Do you bounce it on the bottom and risk getting stuck or do you retrieve with normal action.
Question 2 : For worm I normally just let it sit on the bottom, and wait for a pick up. Is this OK?
Please advice.
Much appreciated
Chris
DropNut
Hi Chris,
Looking at Q1: Maybe you should look at the weight that you are using. I never use more than 1/8 ounce and no:4, when I am in the gulleys. I think the fish trick might only work in a gulley that has a lot of Blacktail in and if the fishing is good.
Q2: Basically sam answer as no:1, but I keep on ensuring that there is not much slack in the line, but I do just let it do its own thing. What I also found that helps in certain gulleys is too cast after the wave set has come in, so that the waves dont throw your bait around as much as normal.
Spot on Dropnut!
The biggest problem in not catching on dropshot is that guys use too heavy leads... watch the guys on ESA, they hardly ever go heavier than the 1/8 oz jigheads. More difficult to cast these lighter jigs, but much more effective because they stay in the water column much longer, instead of hitting the seabed with a thump. 2c - Use it, lose it.
Orange Elephant
I saw a reply by Neptune
Guys.
A really good lure/technique I've found for Leeries and other predators, especially in estuaries if the fish are on top.
Lose the jig head. Get yourself some x-Strong wide gap worm hooks like these:
Then find yourself some plastics like these sort of shape. Most plastics work, but these are dynamite:
White is always a good colour.
These can then be fished like a topwater bait such as a Zara spook or mirrolure with a walk the dog style retrieve ( Tie the hook with a loop knot such as a rapala knot )which give the wrm a side to side zig zag action, and they sit just under the surface and push a wake...
If you want the bait to get down a little deeper, or sink quicker, what you can do is get some galvanised nails. And cut the tips off in the length you need ( 1 or 2 cm ) then push these into the bait, length wise. This will hell the bait sink evenly but give you additional casting weight, as well as a quicker sink.
As these baits are weedless, you can also fish them right up into the really skinny water...
These hooks also give great purchase in fishes mouthes, and are pretty strong... I've taken Tarpon to 15 kilos on this set up, Kingies to around 8 kilos, as well as snapper and all sorts of others...
Hope this helps.
Paricularly good baits for these are Strike King Saltwater Zulus.... not available in this country, but you can get them on the net and they are worth the cash!
I still want to try it as it makes a lot of sense to me. The less the weight the more the action. please let me know if anybody has used it
