Drag washers & stuff
Bliksem
I think this topic has been beaten to death but.....
Prior to joining Sealine I knew sweet nothing about Carbontex, Cal's Drag Grease, ReelX, etc. On 6 March I took the plunge and ordered "maintenance" goodies from Charkbait and it arrived today. Reading Alan Tani's articles didn't help much to keep me from parting with some dough either.....Thank's Alan; I learnt a lot! So what I did was to take (as in buy) a new Torium 30 and checked the drag as bought. It was 10kg as measured with a spring scale (the digital one was to erratic). Then I stripped the reel and got "some" grease (to be disclosed later.....LOL) to the washers. The same scale then showed 12kg. A 20% increase and I still think that I over-greased it. So this stuff arrived here today and I'll try my best this weekend to:
  • strip and remove the current grease (on the std washers) with Benzine,  regrease them with Cal's Grease and test the drag [/*]
  • strip again, fit the Carbontex washers (greased with Cal's, of course) and test the drag [/*]
  • fit new "uprated" drive plate and test the drag [/*]
  • do you also think I'm nuts? :doh[/*]
A short while ago someone on Sealine asked about import duties, freight etc. My costs were in USD:
Grease 6.99, ReelX 4.95, CorrosionX 6.95, Carbontex 18.00, TN30 driveplate 18.00, Postage 25.00
Local costs:
VAT R66.61, Clearance fee R25.00. Duty R0.00
Hooked
Awesome be great to actually hear the results , great stuff.
One point , after you clean the drag washers with benzine , dry them with a hair dryer or something to really get the solvents out of the fibres.Solvents can take up to a week to evaporate under normal temps in a tight weave.
Nicely done bliksem...a wise move you wont regret...now how about posting the drag results that u achieved before and after the upgrade..
Ps.keep the old washers..u can prob sell them as they retail for over a hundred bucks each when new..
Bliksem
It's halftime (Bulls & Reds), so a quick update. Before stripping the drag this morning I just did a control reading and it was still on 12kg max. So, I stripped, cleaned and regreased the std washers with Cal's. It increased to between 14-15kg where the line snapped (3x). Suffix Excelon 21.3kg. Back to the game now.
Bliksem
At the end of my testing session the cycle time for swapping the drag washers was a mere 12min.:D So, here is the results of a case study. It might differ in other applications. The object was to test max drag on a Torium 30 (line = Sufix Xcelon 21.3kg). It was done in the following order:
  • as bought = 10kg[/*]
  • std washers with Quicksilver grease = 12kg[/*]
  • std washers with Cal's drag grease = line snapped @ 14 - 15kg[/*]
  • std washers with Cal's drag grease + Cal's "uprated" drive plate = as above[/*]
  • Carbontex with Cal's drag grease + std drive plate = 8kg[/*]
  • Carbontex with Cal's drag grease + Cal's "uprated"drive plate = 8kg[/*]
  • std washers with Cal's drag grease + std drive plate = line snapped @ 13kg+
Conclusion: Any comments? :spite
I sommer did a line test with a digital scale as well (FWIW, the best of 3 pulls):
Double X High Abrasion 15.91kg = snapped @ 9.3kg (58%)
Sufix Xcelon 21.3kg = 15.2kg (71%)
Maxima Ultragreen 12.5kg = 11.5kg (92%)
::eek:op::
Who knows whats cutting here?
BTW- Bliksem, thanks for sharing all this stuff with us! Good stuff man... Mana to you!
Bliksem
I'm led to believe that the PA system at Suncorp was not tuned to bilingual mode; no "LIEFLING" there as well as no Willie Roos.....
