Tight enough so that the line doesn't slip prior to releasing when casting with heavier lures, to prevent sliced fingers. Also tight enough to get the hook point set and prevent a strong fish from running you into the reef while you fiddle with tightening the drag.. Loose enough so a strong fish doesn't pull you off the rocks or off your feet and also loose enough to give just before your weakest connection. If you need to lockup in a fight it is just a small adjustment. It is also a matter of preference and depends on your target fish.
