Downriggers rockcod/grouper 100m - help
fedu
I've been thinking about getting 2 outriggers for my boat but have a couple of questions that would apreciate some help with:
I would like to know if it's possible to use downriggers to troll from 80 to 100m  depth for grouper/rockcod and other bottom fish.
What would be a good downrigger setup for this ?
The usual dowrigger balls or something like z-wings ?
I have no previous experience with downriggers :) , and would like to use lures not bait..
Fin-S
Hi fedu,
The short answer is yes it is. Most of the big dogtooth from Tanzania are caught this way, as are the big PV yellowfin. However, they are all on livebait not lures - the trolling speed will be the limiting factor.
A standard ball is used on 200lb braid (stay away from wire as it hums with vibration). The scope is normally 40% at 2 knots without current.
The deepest I have gone with lures was 60 metres in freshwater at 5 knots - the scope is about 100%. The problem is the speed makes the ball spin causing a mess of note!
I have not used z-wings at this depth.
A major point to consider if you are going to do this regularly is to order electronic downriggers or bring a strong mate with you - retrieving a 10lb ball from 140m is not easy!
You are in a wonderful place to try and the results could be fascinating.
nicos
You should have grabbed a Z-wing from me while you where here! As you know we are also planning some deep adventures (sounds like the name of a german blue movie), we should compare notes!
fedu
I'm not as ambitious as you guys ;-)
My plan is more a tool to discover new jigging spots faster, covering more area in less time, it will probably be usefull on my future northern trips.
Also to "harvest" some 40 to 60 meters deep spots I allready know but that the fish doesn't usually stay in the same place (Cuberas they like to patrol the area instead of staying in just a place)
