DORINDRAAI
KING.G
ive seen some huge fish been pulled out there wanting to know what size gut would be a safe way to with out losing them lovely monster fish please could need some help^^..
KING.G
then why is it people say rather go for a thiner line is it to cast far seeing that i dont have a bait boat yet or are they just messing me around theres so many sizes to pick from but thanks for the info
It depends on the venue and the fish. Wether we like to admit it or not, we sometimes underestimate a venue. I think that every angler going for big fish has lost big fish due to underestimating the strength of a big carp. If you are going for big carp then you need the correct tackle. There is no room for error and no room for a compromise. Even with the correct tackle, you will still loose the odd big carp for a whole host of reasons. You simply can't cancel out losing the odd fish, BUT you can cancel out causing damage/polution to the environment.
1. If there are snags in the water, DON'T fish without a boat. If you get snagged up, go and try to retrieve your tackle. If you do need to break off and you are directly above or near your tackle, most times only the hooklink breaks.
2. Fish waters with the correct tackle and don't fish a water or swim that is logically unfishable.
I follow these two rules when fishing and I rarely loose any tackle. I havn't lost tackle in a very long time and when I did it was hooklinks. I apply this rule to all my freshwater fishing. Obviously the boat isn't always with we, but then I'm fishing open waters where a boat isn't necessary. There are dams I simply don't fish without a boat. Now this isn't easy and it means that you can't fish certain venues if a boat isn't allowed or if you don't have a boat and it means you can't go catch big carp if you don't have the correct tackle, but hey it's not easy being a responsible angler. That's probably why most anglers simply "go fish". Big carp fishing is like shark fishing - go big or go home. and by that I mean that if you are not prepared you won't be landing many if any big carp. You might hook them, loose them, leave line and other tackle behind and remember, everytime a big carp gets hooked and lost with line and tackle attached to it, it becomes more difficult to catch, especially in small venues.
My advice is to slowly build yourself up to a level with the correct equipment and experience, catching carp along the way, bigger and bigger carp, until you really are catching the big ones. Even if you go and buy every single correct piece of tackle, inexperience with your tackle counts aginst you. A big fish, regardless of the species, tests your angling capabilities and your tackle to the limits, getting to the point where you are consistently landing big fish is not an instant goal and it takes time and the correct equipment is only part of it.
Thats my advice - use it or don't use it. Most people don't use it and just can't resist taking the quick route to catching big fish and well I have heard stories from many about "the one that got away"...
KING.G
thanks very much i will use your advice sure could use alot more anglers with an understanding like you.
HennieB
You'll also need an inflatable boat or dinghy at Doorndraai to retrieve snagged up fish and also remember that you're fishing at distances at anything from 250 meter minimum.
KING.G
Im camping over there this weekend is the fishing beter on the dam wall side:fishn where the the jetty is or the opposite side
pumamangp
well said Stefan. must agree 100%
if you hook it you gotta be able to land it.
