Differences between Exage rods.
fisher
What are the differences between the Shimano Exage rods like the 1468 and 110H?
Is it the size of the rod that's different?
Pylstert
1468 = 14ft length and rated to cast between 6-8 ounces
110H = 110 heavy 11ft lenghth and rated to cast something like 8 ounces but works nicely with a 4 oz too
The Exage 110 is rated to throw 250g - that's a NINE ounce sinker...!!:shock:
There is a massive difference in quality between the 1468 and the 100 and 110 versions of the EXAGE rod. The 100 and 110's are both HMG rods... rated at 200g and 250g casting weight respectively. When you have a manufacturer printing their rating on the blank, you can take it for granted that that rating is well within it's strength range... at 250g for a 11 ft rod?!?! Thats got to have some serious backbone. I have owned/own the 1468/1446/100S/110S&H/80S - there is a marked improvment in the build quality of the shorter rods - HMG blanks, Fugi guides, Metal ferrules, trigger winches standard etc. While many anglers have landed good fish with the Exage 1468, there are many stories of breakages, especially with the inferior guides that the first Exages came out with.
Gerhard
Reefman,
Would you say a Shimano Torium 30 with the Exage 110H would be a good combination for casting plugs and jigs from the shore in Angola?
Think I have to get a couple of that 4 oz Williamson GT Poppers before I get out of Dubai....
Gerhard... no bru... the Torium 30 is too big for the Exage 110. It will be an unbalanced setup. Rather go for the Saltist30/Saltiga30surf/Trini16 - something in that size range... or alternatively, an even better idea, would be to get the 100S Exage, which is the spinning rod version of the 110 - Then you can match it with one of your Spinning reels...? I use the 110 when I need to cast much further, but for spinning the 100 is just beaut! I match mine up with a Stella 6000.
Williamson poppers... nah... save yourself some money - buy some cheap Halco Roosta's - the red and white one is lethal during the sunshine... also the orange and pink Roosta.... then some of the darker coloured Strike pro/Halco's for the evenings/dawn - it'll save you a fortune. The fancy Williamson Poppers with the jetstream behind it...? never caught a thing on it...
Then don't forget to get yourself some genuine Aubrey de gama chisel nose plugs... they're awesomely effective! They also save you much energy... which is a good thing when you're tired...
Gerhard
Thanks Reefman,
Guess I will have to start looking for a Stradic 6000 or 8000 and load that with 25lbs Tuff line...
fisher
Reefman, what is the difference between the Exage 110 S & H?
Is it the weight or length?
And approx. how much does the 110 weigh?
Thanks.
PS : If fishing for edibles what would you believe to be the best Exage rod to choose, the 110H?
Nah I got confused for a moment there... ( it's happening more and more these days..:doh)... The Rod's full name is the Exage SF (SURF) 110H. And the Exage SF100. There is no S version... They both have the SF before the number...
So you get the 11 foot Exage SF110H
and the 10 ft Exage SF100.
The H refers to Overhead casting rod - ie: you must use a multiplier reel with it. It has a short butt.
The 100 version is a spinning rod, used with spinning reels (coffee grinders). They have a long butt.
Weigh? Got no idea, but it's probably less than a kilo???? Very light?
For edibles... if you want a scratching stick (small baitfishing) and you can cast a multiplier , then the 110 is the one...
If you battle with a multiplier, then the 100 is better...
kavin
The guides on my 1468 have given me endless problems with the inners giving up quickly and i had to reguide them. There was also a problem getting the correct replacement colour so i had to overhaul all the bindings. This was done at Basilmanning who did an excellent job of it.
My 2cents worth.
Gerhard
Ok,
So now I have a Trini 16.
What line do you suggest I put on it? Was thinking 25lbs Tuff line xp.
This will go on to the 110.
Put a GT Ice cream on the line and I should be casting it a mile for Jack Cravelle or Cebera Grouper....
Any suggestions with the setup combination will be appreciated.
JCW
i have also recently been looking at the 110 H for edible fishing from the rocks - Galjoen and Cracker and for throwing the odd spoon.
doing the research on the rod i see it is quite a old model. Are there any other rods that compete with this rod or maybe better.
i am going to pair it up with a Daiwa sl30
