Denso Hooks
Naruto
Bought these hooks on saterday for use during our club camp in November to target some catfish. What do you think?
Skuimkop
Lyk vir my ook na 'n solid hoek en ek hou van die 'profile' as ek dit so kan stel van daai hoeke. Wat prys hulle?
Hehe......They're my hooks.
Slightly inturned tip to assis working a bit like a circle, reducing gut hooking
I landed my 235kg Raggie on the 10/0's
Enjoy them
Naruto
Craig I was waiting for you reply...
I was actually hoping to get the 8/0's but they only have 6/0, 10/0 and 12/0. They look really like they can do the business. Will be targeting the Vaal cats first weekend of November at Tago.
Naruto
With barbel it is best(I have found) to let the fish run a few times before setting the hook. Setting the hook is done by gradually slowing down the run and then tightening up fully to ensure the hook sets. I am no expert, but this is what has worked for my.
nobbles
Ya so the same process as the circle. Im slowly getting the hang of the circle. I slowly tighten my drag on the grinder and when the drag is tight enough i slowly raise the rod. Have had very good hook up rate like that. On my multiplier i have it on free spool with the racket on, i let the fish take the bait go screaming off, than i engage the reel by flipping the switch and raise the rod. So far i have not lost a fish on a cirlce on the multiplier doing that and all hook ups so far in the corner.
FeedingFrenzy
Nice solid hook that - I will beacquiring some of those for my in-ed fishing!
OK a bit off topic but after reading some of the posts I would like to share my tip for 100% barbel hook rate!
One of the reasons why so many barbel runs don't conclude in a hook-up is because of the way it holds the bait when moving off.  They clamp the bait in the harf biting pads.  No way a hook is going to get purchase there.  So many time I would have a big snorbek pick up the bait and slowly move off only for me to tighten and bogerol is on the other end.  I even tried letting the fish run a few times and got some success but pulled the hook more often than not.
So I deveised a cunning plan!  When building your rig - slide a suicide hook onto the hook snodd first and then tie on whatever hook you normally use on the end.  Hook the free sliding skelm hook into the top end of the bait.  You will find that each and every run can be picked up straight away - and the skelm hook will be deeply bedded into the corner of the mouth or into the base of the whisker.  Guaranteed.
Important:  fish with a skightly slack line - it results in more positive pick ups.
Robin
Ant86
My circle method,
Let him take a nice long run,slightly tighten drag on grinder and then grab and hold spool to set the hook.
When you grab and hold the spool it gives it a bit of a "shock" and stops the cat in his tracks and sets the hook nice and deep in the corner.
nobbles
Not abd idea. That is the same thing it is doing when i flip the switch on my multiplier. Suddnely full drag and slight rod lift. Gets them everytime
Well so far
Couta-Cuack
Okay now I am a bit confused, we have always fished heads as bait with either a large single hook trough the top lip or a 2 hook rig with the second hook more to the back of the head bait.
I must say we also missed quite a few bites and after reading the post about the cat holding the bait in its mouth I understand better why.  The problem with the two J hook rig for me is that the second hook very often turns into the bait and doesn't help with the hookup at all.
So my question is this, should I go for the circle hook next time or the two J hook setup and just find a way of positioning the second hook better?
We are going to De Hoek 18th November and I want to try a different option.
I would appreciate some responses
Thank you.
nobbles
To be honest id use circle hooks. I will never use a j hook on babrel again. Cirlce hooks just work better and suit the bite of a cat perfectly. The cat will hook itself on the hook and you wont rip the hook out its mouth by striking. So far the only fish i have lost have been my error and once my bait slipped over the gape of the hook, again my error. Ill always go for the setup that will benfit me, so far circle hook is number one.
Couta-Cuack
Thank you for the reply nobbles!
I was also starting to lean towards the circle hook after reading some more posts.
Just one more question and that is how do you hook the circle?  Trough the lip or on a kind of hair rig with a second smaller hook or I thought of tying it with wax cord as you would a bonnie trough the eyes for bill fish? hehe
Cheetha FS
You can always put a circle at the bottom of your trace and a J hook above it. Use toothpics to secure ur bait and hook.
Ant86
Circles all the way,
On a head bait you can use a J hook to hook into the bait and then have the circle fully exposed.Check the enigma De Hoek thread for pics.The other method is to hook through the lips.
See 1st post in this thread
http://www.sealine.co.za/view_topic.php?id=25843&forum_id=64
On the Subject of De Hoek I was there on the weekend,un fortunately the weather was dreadful so was the fishing.There is A LOT OF STRUCTURE,dont be scared to use heavy tackle,50 lb mainline and 0.75mm leaders and more 10/0 to 14/0 circles.The guys next to me put out a few heads,they had about 5 hook ups and got cutoff everytime.I had 2 burnoffs using 50lb braid.
I have been using the Mustad Zsteel circles 10/0 and 12/0,and the Owner 9/0 tournament circles-very impressed .
Another good option are the eagle claw circles,got myself some 10/0' but havent used them yet.They look quite solid though.
My other favourite circle bait method is my chicken heart sosatie, to basically catch any cat that passes your bait,to keep you busy while you wait for a big cat on your head baits.
Buy some chicken hearts at pick&pay.
Rig is as follows ;use a sliding sinker and a 1m mono leader of about .55mm or so.
use a single 7/0 circle.
Thread the hearts through the hook and up the leader so that they are just above the hook which is fully exposed.thread about 5 or 6.
10 to 15 minutes and you should be on.
I some times also add a feather skirt,I will try and post a pic but its a deadly bait if you just looking for some action espcially on the light tackle.
good luck
Couta-Cuack
Thank you for the advice Antjar.
Then it is settled , im gonna go with the circles!  It will probably take a bit of experimentation but im sure Ill get it right! ::S
My barbel gear is rigged with 40lb braid but Im going to take my jigging reel with as well which is loaded with 80lb braid!
Sorry to hear it didn't go well when you were there!  De hoek can sometimes be very temperamental as im sure you know!
