kopstamp wrote:
I've already repaired it.
The "string" that holds the weight cord to the mesh snapped and unravelled.
I then used 0,60mm mono and attached the weight cord to the mesh with that. It then lasted several months but on my last 2 outings the mesh started to tear 1 - 3 rows above the weight cord.
The way to overcome it would be if the took about 5 rows and had a double mesh so that the force of the weights gets distributed over the bottom 5 rows and not just 1 row at the bottom. This would also help with abrasion resistance as those bottom few rows are always being dragged along the bottom when you retreive the net.
The double mesh at the bottom should also be made of thicker nylon.
Anyway aven if they could do all this it would probably be so expesive if done by hand afterwards that it wouldn't be worth the extra money.
If manufactured like that the extra cost would be negligable.
just phoned them now, they have ones up to 8ft.
Can you send me a pic of where the tear is. maybe the can strenthen it for you?
must add they also import...
