daiwa sealine-x 50
roland
hey gents.
any , i mean any info regarding this reel would be of great help. was given one (aint God good) and know nothing about them. main use etc? will it pull a 100kg toothy? or mainly eds?
thanks in advance
mikesfb
Ok this is the only sealine x i could find and if im correct then what you have is the original grandwave before it was named a grandwave, but i may be horribly wrong. courtesy of www.fishingtackle.co.za
View Full-Size Image
Daiwa Sealine X Model SL-X30SHA reel
Price: R1433.00
Ask a question about this product
[line]
Daiwa Sealine X Model SL-X20SHV reel. Combined With our unique Super Speed Shaft for longer, easier casts, quite simply these are the most free running reels you will have ever handled. The 20SHV and 30SHV are superb on the shore, hitting big distances with even heavyweight gear and at sea where the ground is rough. Super Speed Shaft, Selectable, centrifugal braking, Three ball Bearings, Waterproof high performance drag, Super-strong aluminium spool, Strong, lightweight composite, Frame and side plates, Balanced aluminium handle, Rod clamp included. Gear ratio 6.1:1, Ball bearings 3, Weight 510g, Capacity .37mm/450m, .40mm/400m, .43mm/350m.
Riaandl
Mike think you are right, the x was brought out just after the Sealine SH range, just a little more bearing and other stuff.
IF it say DAIWA is a good reel
roland
I spooled it with .45 suffix synergy with a .70 leader and for the love of anythins with fins, i cant cast this reel. Lol. Its to fast. Will be looking for break collars or something for it
roland
Fishy
Very good reel & it will do the job. I have 2 of them in the 50's. The only thing I'de suggest you do is to change the handle in time to come to stainless steel ones as they do corrode with time.
