Daiwa reels.
flippy
Saltiga S-Extreme 600 For the first time an overhead jigging reel made for Australia, designed in collaboration with Daiwa Japan and Daiwa Australia, the Saltiga S-Extreme 600 is the ultimate overhead jigging reel available.
Internally the Saltiga S-Extreme 600 is built to take the punishment from the strongest fish in the sea. Built on a solid one piece machined CNC aluminium frame and side plates, all the internal components are built directly onto the frame for ultimate strength and perfect alignment. Backed up by some of the strongest gearing available , Hyper Digigear and a massive 10 element hyper tournament multi disc wet drag system it delivers unrivalled power with smooth even drag pressure even when pushed up to its full power.
Designed around a concept to create some of the greatest jigging gear available the Saltiga S-Extreme is Australia’s first and only jigging gear built for downunder.
  • CNC – machined one piece aluminium body and side plates[/*]
  • Hyper Digigear[/*]
  • Dual system infinite anti-reverse[/*]
  • Grease impregnated multi disc 13 kg drag system[/*]
  • Precision machined alloy spool for maximum strength[/*]
  • Oversized “Quick Drag” star drag[/*]
  • Machined aluminium jigging ball knob with swept in handle[/*]
  • Non-set plate design. Inner parts built directly onto frame for dead on alignment[/*]
  • 7 ball bearings inc CRBB’s (corrosion resistant ball bearings)[/*]
  • Machined alloy rod clamp[/*]
  • Ideally matched to the S-Extreme 56XHFB rod[/*]
  • 5 year warranty[/*]
Model Gear Ratio #Ball Bearings Drag (kg) Weight (g) Spool Capacity (m/lbs) Saltiga S-Extreme 600 4.2:1 7+1 13 700 60lb/400m, 80lb/300m
flippy
Sealine SL-SHB This year Daiwa fully upgrade the old faithful “Slosh” with new cosmetics, handle and bearings.
The ultimate in live-bait and jigging high speed reels. The SL-H reels offer incredibly long casting ability and has built an enviable reputation as the must have high speed rock spinning reels. Backed up by the ultra strong Power Mesh gearing these reels will take on anything that swims.
  • Power mesh drive[/*]
  • Long cast composite spool[/*]
  • 2 CRBB bearings[/*]
  • Smooth Teflon impregnated felt drag washers[/*]
  • Ultra fast 6.1 : 1 retrieve[/*]
  • Powerful low centre handle placement[/*]
  • One piece frame with frame guard[/*]
  • Free spool adjustment[/*]
  • Spool ratchet[/*]
  • Balanced power handle[/*]
  • Oversized machine cut bronze gears[/*]
  • Centrifugal spool brake[/*]
Model Gear Ratio #Ball Bearings Weight (g) Drag (kg) Spool Capacity (m/lbs) SL20SHB Hi-Speed 6.1 4 405 7 12lb/380, 14lb/300, 20lb/210 SL30SHB Hi-Speed 6.1 4 475 7 14lb/490, 20lb/295, 25lb/235 SL50SHB Hi-Speed 6.1 4 630 7 25lb/450, 30lb/380, 40lb/310
flippy
Saltiga-S Extreme For the first time a jigging reel made for Australia, designed in collaboration with Daiwa Japan and Daiwa Australia, the Saltiga S-Extreme spinning reels represent the ultimate jigging reel.
Taking the best of the best features from the extensive range of Saltiga spinning reels to build one new high performance series for Australia, the new Saltiga S-Extreme is Daiwa’s best heavy duty spinning reel.
Incorporating Daiwa’s famous engineering technology, the Saltiga S-Extreme series utilizes the strongest gearing in the world, Hyper Digigear, made from C6191 marine bronze which is digitally cut for perfect meshing and incredible strength. With the ultimate in gear design, reels like this need to be backed up by one of the strongest smoothest drag systems featured in any reel available today. Sealed for performance and protection, the newly developed for Australia only, S-Extreme hyper tournament wet drag system, exudes upwards of an incredible 30 kilograms of pressure on the 6500 size and 10kg on the 4500 size with ease.
For increased cranking power the S-Extreme reels feature a new improved handle design and machined custom jigging ball knob for increased power and comfort.
These amazing reels just need the ultimate rods, designed to match the performance of the new reels, these awesome new rods.
For the best performance money can buy the new Saltiga S-Extreme spinning reels are guaranteed to set the new standard of ultimate performance.
  • ABS spool[/*]
  • Twistbuster II[/*]
  • Extra large line roller[/*]
  • Sealed saltwater proof S-Extreme hyper tournament drag[/*]
  • Sealed line roller[/*]
  • Sealed gear box[/*]
  • Airbail[/*]
  • Rugged distortion free super metal body[/*]
  • Rotor break to prevent accidental bail closure[/*]
  • One piece machined aluminium handle[/*]
  • Machined aluminium ball knob[/*]
  • Full time dual stopper infinite anti-reverse[/*]
  • Washable construction[/*]
  • Ultra precision computer designed C6191 marine bronze gearing[/*]
  • Zero friction main shaft[/*]
  • Rugged advanced level wind[/*]
PERFECTLY MATCHED WITH Model Gear Ratio #Ball Bearings Weight (g) Drag Pressure (kg) Spool Capacity (m/lbs) S-EX 4500Z 4.9 (94cm) 13+1 570 10 PE 3/300m, 4/220m S-EX 6500Z 4.3 (101cm) 13+1 820 30 PE 5/500m, 6/400m S-EX 4500H MAVERICK 5.7 (108cm) 13+1 570 10 PE 3/300m, 4/220m S-EX 6500H MAVERICK 6.2 (142cm) 13+1 830 30 PE 5/500m, 6/400m
Spinnerman
If the new SL0SH series is becomes available in a 40 wide and is as good as its predecessor, it will become an all time hit here.
Only thing is Daiwa prices?
