daiwa baitrunners
eenklip
Hier is een wat ek na gekyk het vir my 10ft stok
Daiwa Regal Plus RGP 3500 Bri Spinning Reels. Bite n Run Series. High performance Carp reels, great all-rounders with workhorse reliabilty. The 6 ball bearings provide powerful yet effortless retreive. In action the variable tension bite n run system allows you to control running fish before switching to the responsive calibrated rear drag. Infinite Anti-Reverse, Level line lay, Spare aluminium spool, Reverse tapered spool for anti backlash, Twist Buster line twist reduction, Six ball bearings. Free spare aluminium spool. Gear ratio 4.9:1, Ball bearings 6+1, Weight 480g, Capacity .30mm/220m, .35mm/155m
christopheradam
Daiwa are a reliable and competetively priced brand that provide affordable value without sacrificing performance, reliability and styling. The only draw back with these reels is their respective line capacities however, there are brands of mono on the market that boast narrow diameters with high breaking strengths that should enable the angler to overcome this "problem".
If my understanding is correct, if you purchase these reels you get a one year warranty with them? (I stand to be corrected about this).
If you have a warranty then part with your hard earned cash and give them a try. Why not?
Enjoy
christopheradam
Enjoy
